tach drive
05-03-2005, 11:18
tach drive
Hi. Does anyone know the brand and where I might be able to purchase
the tach generator on a DD 6V92. It looks like a mushroom with 2 wires and is located on the engine near the valve covers Thanks a bunch Vaughn 1982 PT40 |
05-03-2005, 11:31
tach drive
Since you did not give your location, it is hard to be specific,
however, any Detroit dealer/distributor should be able to fulfill your need. Also Most speedometer shops carry all kinds of instrumentation and related senders. I have usually found them to be the most economical. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Vaughn Paul wrote: > Hi. Does anyone know the brand and where I might be able to purchase > the tach generator on a DD 6V92. It looks like a mushroom with 2 wires > and is located on the engine near the valve covers > > Thanks a bunch > > Vaughn > 1982 PT40 > > > > > > > Yahoo! Groups Links > > > > > > > > > |
05-03-2005, 12:01
tach drive
I believe that George is on the right track. If they are the senders
with one end capped (cable in/out), I have used vehicle speed sensor/senders I raided out of Prince On Board Computers, they were also used as cruise-control speed sensors. Otherwise there is always the old BlueBird parts department, ... - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > Since you did not give your location, it is hard to be specific, > however, any Detroit dealer/distributor should be able to fulfill your > need. Also Most speedometer shops carry all kinds of instrumentation > and related senders. I have usually found them to be the most > economical. > > George Lowry > '95 WBDA 4203 & GM 4106 (for sale) > Spearfish, SD > > Vaughn Paul wrote: > > > Hi. Does anyone know the brand and where I might be able to purchase > > the tach generator on a DD 6V92. It looks like a mushroom with 2 wires > > and is located on the engine near the valve covers > > > > Thanks a bunch > > > > Vaughn > > 1982 PT40 > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > |
05-03-2005, 12:07
tach drive
I am near Missoula, MT. The DD dealer here could not provide any
assistance, and Earl at BB was at a lose. thanks a bunch --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > I believe that George is on the right track. If they are the senders > with one end capped (cable in/out), I have used vehicle speed > sensor/senders I raided out of Prince On Board Computers, they were > also used as cruise-control speed sensors. > > Otherwise there is always the old BlueBird parts department, ... > > - Jeff Miller > http://www.wanderlodge.net > http://www.millercoachworks.com > > > --- In WanderlodgeForum@yahoogroups.com, George Lowry > wrote: > > Since you did not give your location, it is hard to be specific, > > however, any Detroit dealer/distributor should be able to fulfill > your > > need. Also Most speedometer shops carry all kinds of > instrumentation > > and related senders. I have usually found them to be the most > > economical. > > > > George Lowry > > '95 WBDA 4203 & GM 4106 (for sale) > > Spearfish, SD > > > > Vaughn Paul wrote: > > > > > Hi. Does anyone know the brand and where I might be able to > purchase > > > the tach generator on a DD 6V92. It looks like a mushroom with 2 > wires > > > and is located on the engine near the valve covers > > > > > > Thanks a bunch > > > > > > Vaughn > > > 1982 PT40 > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-03-2005, 12:19
tach drive
I bought mine from Holland Motorhomes in Holland, MI.
It was a used part. I would bet that a Detroit Dealer worth its salt would be able to find you one. What is your tach doing? Jay Darst 85PT40 6V92 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "Vaughn Paul" wrote: > I am near Missoula, MT. The DD dealer here could not provide any > assistance, and Earl at BB was at a lose. > > thanks a bunch > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > I believe that George is on the right track. If they are the > senders > > with one end capped (cable in/out), I have used vehicle speed > > sensor/senders I raided out of Prince On Board Computers, they were > > also used as cruise-control speed sensors. > > > > Otherwise there is always the old BlueBird parts department, ... > > > > - Jeff Miller > > http://www.wanderlodge.net > > http://www.millercoachworks.com > > > > > > --- In WanderlodgeForum@yahoogroups.com, George Lowry > > wrote: > > > Since you did not give your location, it is hard to be specific, > > > however, any Detroit dealer/distributor should be able to fulfill > > your > > > need. Also Most speedometer shops carry all kinds of > > instrumentation > > > and related senders. I have usually found them to be the most > > > economical. > > > > > > George Lowry > > > '95 WBDA 4203 & GM 4106 (for sale) > > > Spearfish, SD > > > > > > Vaughn Paul wrote: > > > > > > > Hi. Does anyone know the brand and where I might be able to > > purchase > > > > the tach generator on a DD 6V92. It looks like a mushroom with > 2 > > wires > > > > and is located on the engine near the valve covers > > > > > > > > Thanks a bunch > > > > > > > > Vaughn > > > > 1982 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-03-2005, 12:47
tach drive
The tach is dead. The shaft on the generator unit broke. Thanks-
- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > I bought mine from Holland Motorhomes in Holland, MI. > > It was a used part. > > I would bet that a Detroit Dealer worth its salt would be able to > find you one. > > What is your tach doing? > > Jay Darst > 85PT40 6V92 > Springfield,IL > > > --- In WanderlodgeForum@yahoogroups.com, "Vaughn Paul" > wrote: > > I am near Missoula, MT. The DD dealer here could not provide any > > assistance, and Earl at BB was at a lose. > > > > thanks a bunch > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > I believe that George is on the right track. If they are the > > senders > > > with one end capped (cable in/out), I have used vehicle speed > > > sensor/senders I raided out of Prince On Board Computers, they > were > > > also used as cruise-control speed sensors. > > > > > > Otherwise there is always the old BlueBird parts department, ... > > > > > > - Jeff Miller > > > http://www.wanderlodge.net > > > http://www.millercoachworks.com > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, George Lowry > > > > wrote: > > > > Since you did not give your location, it is hard to be > specific, > > > > however, any Detroit dealer/distributor should be able to > fulfill > > > your > > > > need. Also Most speedometer shops carry all kinds of > > > instrumentation > > > > and related senders. I have usually found them to be the most > > > > economical. > > > > > > > > George Lowry > > > > '95 WBDA 4203 & GM 4106 (for sale) > > > > Spearfish, SD > > > > > > > > Vaughn Paul wrote: > > > > > > > > > Hi. Does anyone know the brand and where I might be able to > > > purchase > > > > > the tach generator on a DD 6V92. It looks like a mushroom > with > > 2 > > > wires > > > > > and is located on the engine near the valve covers > > > > > > > > > > Thanks a bunch > > > > > > > > > > Vaughn > > > > > 1982 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-03-2005, 13:01
tach drive
Here are a few ideas:
http://www.ptcpower.com/inventory_detroit_engines.aspx http://www.clarkedda.com/ http://www.detroitdiesel.com/index.asp http://www.scharfco.com/default.htm This last one would be my favorite place to shop for great used parts. They have been in business a very long time and are honorable. Jay Darst 85PT40 6V92 SpringfieldIL --- In WanderlodgeForum@yahoogroups.com, "Vaughn Paul" wrote: > The tach is dead. The shaft on the generator unit broke. Thanks- > > > > - In WanderlodgeForum@yahoogroups.com, "Jay Darst" > wrote: > > I bought mine from Holland Motorhomes in Holland, MI. > > > > It was a used part. > > > > I would bet that a Detroit Dealer worth its salt would be able to > > find you one. > > > > What is your tach doing? > > > > Jay Darst > > 85PT40 6V92 > > Springfield,IL > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Vaughn Paul" > > > wrote: > > > I am near Missoula, MT. The DD dealer here could not provide any > > > assistance, and Earl at BB was at a lose. > > > > > > thanks a bunch > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > > > I believe that George is on the right track. If they are the > > > senders > > > > with one end capped (cable in/out), I have used vehicle speed > > > > sensor/senders I raided out of Prince On Board Computers, they > > were > > > > also used as cruise-control speed sensors. > > > > > > > > Otherwise there is always the old BlueBird parts department, ... > > > > > > > > - Jeff Miller > > > > http://www.wanderlodge.net > > > > http://www.millercoachworks.com > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, George Lowry > > > > > > wrote: > > > > > Since you did not give your location, it is hard to be > > specific, > > > > > however, any Detroit dealer/distributor should be able to > > fulfill > > > > your > > > > > need. Also Most speedometer shops carry all kinds of > > > > instrumentation > > > > > and related senders. I have usually found them to be the most > > > > > economical. > > > > > > > > > > George Lowry > > > > > '95 WBDA 4203 & GM 4106 (for sale) > > > > > Spearfish, SD > > > > > > > > > > Vaughn Paul wrote: > > > > > > > > > > > Hi. Does anyone know the brand and where I might be able to > > > > purchase > > > > > > the tach generator on a DD 6V92. It looks like a mushroom > > with > > > 2 > > > > wires > > > > > > and is located on the engine near the valve covers > > > > > > > > > > > > Thanks a bunch > > > > > > > > > > > > Vaughn > > > > > > 1982 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-03-2005, 13:24
tach drive
If it's the little drive tang, it is just an insert. The insert /
adapter pin should be available from a speedometer shop. I might not be thinking of the right sender though, ... call Ken at HMH in Holland and he might be able to get one for you. --- In WanderlodgeForum@yahoogroups.com, "Vaughn Paul" wrote: > The tach is dead. The shaft on the generator unit broke. Thanks- > > > > - In WanderlodgeForum@yahoogroups.com, "Jay Darst" > wrote: > > I bought mine from Holland Motorhomes in Holland, MI. > > > > It was a used part. > > > > I would bet that a Detroit Dealer worth its salt would be able to > > find you one. > > > > What is your tach doing? > > > > Jay Darst > > 85PT40 6V92 > > Springfield,IL > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Vaughn Paul" > > > wrote: > > > I am near Missoula, MT. The DD dealer here could not provide any > > > assistance, and Earl at BB was at a lose. > > > > > > thanks a bunch > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > > > I believe that George is on the right track. If they are the > > > senders > > > > with one end capped (cable in/out), I have used vehicle speed > > > > sensor/senders I raided out of Prince On Board Computers, they > > were > > > > also used as cruise-control speed sensors. > > > > > > > > Otherwise there is always the old BlueBird parts department, ... > > > > > > > > - Jeff Miller > > > > http://www.wanderlodge.net > > > > http://www.millercoachworks.com > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, George Lowry > > > > > > wrote: > > > > > Since you did not give your location, it is hard to be > > specific, > > > > > however, any Detroit dealer/distributor should be able to > > fulfill > > > > your > > > > > need. Also Most speedometer shops carry all kinds of > > > > instrumentation > > > > > and related senders. I have usually found them to be the most > > > > > economical. > > > > > > > > > > George Lowry > > > > > '95 WBDA 4203 & GM 4106 (for sale) > > > > > Spearfish, SD > > > > > > > > > > Vaughn Paul wrote: > > > > > > > > > > > Hi. Does anyone know the brand and where I might be able to > > > > purchase > > > > > > the tach generator on a DD 6V92. It looks like a mushroom > > with > > > 2 > > > > wires > > > > > > and is located on the engine near the valve covers > > > > > > > > > > > > Thanks a bunch > > > > > > > > > > > > Vaughn > > > > > > 1982 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
05-03-2005, 17:49
tach drive
wrote: > Hi. Does anyone know the brand and where I might be able to purchase > the tach generator on a DD 6V92. It looks like a mushroom with 2 wires > and is located on the engine near the valve covers > > Thanks a bunch > > Vaughn > 1982 PT40 If it says 8 pules per rev and part number 59d-02392-2 or sn95 contact egauges dot com 1 800 303 6211 Thay have senders with cable. Ken 1982 fc BC |
