Jacks not functioning properly
05-16-2007, 05:04
Year and model of your BB???
Kevin
YL CA
86 38 PT
05-16-2007, 08:57
Hello, We just went to get our bus from Olympia Washington. When we
got home, the jacks did not work properly. The pannel came on like
normal, but when we went to press the button it just made a clicking
noise that could be heard both inside and out. Finally they went down
after many tries of pushing the button. After they set they could not
be adjusted - like the controls were not working?? Any help would be
greatly appreciated!
Thank you!
Teri & Robert Rahn
Kalispell, MT
05-16-2007, 09:44
Opps, Sorry.....Forgot that part.
It's a 1988 pt 40
Thanks,
Teri
05-16-2007, 12:40
Probably the relay located under the bus behind the steps. Lay down and
look behind the steps and you will see a selenoid that has various
cables coming out of it. Thes get loose and corroded. Clean these and
tighten, this might do it. Did for us.
Bob Lawrence
84 PT36
Tacoma, Wa.
--- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn"
down
not
> Thank you!
> Teri & Robert Rahn
> Kalispell, MT
