Watts Quick-connect
07-17-2007, 07:53
Watts Quick-connect
Folks,
I'm gearing up to plumb my aqua-hot and stumbled
across Watts connectors at the local ACE hdwr store:
http://www.watts.com/pro/_products.asp?catId=71
These fittings can fully rotate under pressure and allow
for easy disconnect and reuse. They are good for 100psi
at 180 deg F. The connectors work for PEX, CPVC,
or Copper; for example, a T connector can connect
all 3 of these materials on any end of the T. Anyone have
any experience using these in a Motorhome application?
David Brady
'02 LXi, Smokey
NC
07-17-2007, 09:47
Watts Quick-connect
Sent: Tuesday, July 17, 2007 2:53 PM
Subject: [WanderlodgeForum] Watts Quick-connect
Davit Do they have built in check valves so you do not dump the system if they
are disconnected?
Bob Loomas 1985 PT 36
Folks,
David Brady
'02 LXi, Smokey
NC
07-17-2007, 10:18
Watts Quick-connect
Not that I know of Bob, but they do have quick-connect
ball valves.
David B
'02 LXi, Smokey
NC
> From: David Brady
> if they are disconnected?
> Folks,
> <http://www.watts.com/pro/_products.asp?catId=71>
> David Brady
> '02 LXi, Smokey
> NC
> Version: 7.5.476 / Virus Database: 269.10.8/904 - Release Date: 7/16/2007 5:42
PM
