Engine alarm
08-13-2010, 03:17
Engine alarm
Hi Gary:
No the light on the dog house lid would not cause that problem. More than
likely, the sender is flaky or you have a broken wire that touches from
time to time. The threads on the sender can corrode causing an insulant
from ground.
Oh, and that print is a chassis print and not made available to us usually.
They could not be found in the archives and were said to be lost when the
computers dumped some time in the past and brought back on line. That is
unless, Parliament Coach has come across them while indexing the file cabinets.
Safe travels,
"84FC35 "Ruff Diamond"
Duncan, Oklahoma
At 03:05 PM 8/13/2010 +0000, you wrote:
>The bus has been in-active for a while getting painted, swing-out radiator
>and a few other mods.
>The engine alarm light is on. Goes off occasionally but comes back.
>Coolant and lubricants have been checked but can't find the source. Purrs
>like a kitten.
>Can someone tell me the title of the drawing that the alarm is on. I've
>got a complete set of drawings but failed to find it on first try.
>The light on the lid of the doghouse is disconnected, that couldn't cause
>it, could it?
>Regards,
>GPSGary
>1984FC35SB
09-05-2010, 06:03
Engine alarm
There is a engine coolant sensor located very high in the system and if you have not burped the cooling system, you will get an intermittent engine light.
gary 85pt40
--- On Fri, 8/13/10, Ralph L. Fullenwider wrote:
Subject: Re: [WanderlodgeForum] Engine alarm
Date: Friday, August 13, 2010, 11:17 AM
Hi Gary:
from ground.
Safe travels,
Duncan, Oklahoma
>like a kitten.
>it, could it?
>Regards,
>GPSGary
>1984FC35SB
