Hpw To Remove Silicone Adhesive from Shower Walls?
08-25-2007, 09:54
Howdy, WanderlodgeForum family.
After bumping it for the umteenth time, Jack removed a soap dispenser from our shower wall. Underneath the backing plate of this dispenser was some sort of silicone adhesive. It is clear and I can pick it off in teeny, tiny pieces. That is not very efficient. We are not sure what material the shower walls are, either. Don't think that they are Corian. Any ideas or suggestions as to how to remove this adhesive? <sigh> Thanks, Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Summering in Buena Vista, CO |
08-25-2007, 10:13
Jack & Liz
The most economical product is WD40 to remove silicone residue. Dampen a rag with it and apply for a few minutes and wipe off with another rag. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 [Non-text portions of this message have been removed] |
08-25-2007, 10:14
From: Jack and Liz Pearce To: WanderlodgeForum@yahoogroups.com Sent: Saturday, August 25, 2007 4:54 PM Subject: [WanderlodgeForum] Hpw To Remove Silicone Adhesive from Shower Walls? You can use Goo Gone.Works good and it does not scraps or leave marks.You can fined it at Home depot or here is the # 800 255 3924 Bob Loomas 1985 PT 36 Howdy, WanderlodgeForum family. After bumping it for the umteenth time, Jack removed a soap dispenser from our shower wall. Underneath the backing plate of this dispenser was some sort of silicone adhesive. It is clear and I can pick it off in teeny, tiny pieces. That is not very efficient. We are not sure what material the shower walls are, either. Don't think that they are Corian. Any ideas or suggestions as to how to remove this adhesive? <sigh> Thanks, Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Summering in Buena Vista, CO [Non-text portions of this message have been removed] |
08-25-2007, 13:01
Don't rule out Corian ... I think my shower walls (in my '95) are
made of the stuff. The silicone adhesive/caulk is difficult to remove, but a single edge razor blade in a flat holder is often able to do the trick. I'v also seen scrapers in the hardware store that hold a utility knife (trapezoidal) blade. These are somewhat more robust than the razor blades. Hardware stores sell a variety of "adhesive solvents" for various products ... but they require testing on a bit of the wall material to ensure that it won't damage it. I'd go with the mechanical (scraping) solution first -- then look for solvents only as a last resort. Always be gentle, as the Corian (or other plastic material) can be easily scratched. If the walls are Corian, they can be restored by much polishing, if you scratch while removing the silicone. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Aug 25, 2007, at 2:54 PM, Jack and Liz Pearce wrote: > Howdy, WanderlodgeForum family. > > After bumping it for the umteenth time, Jack removed a soap dispenser > from our shower wall. Underneath the backing plate of this > dispenser was > some sort of silicone adhesive. It is clear and I can pick it off in > teeny, tiny pieces. That is not very efficient. We are not sure what > material the shower walls are, either. Don't think that they are > Corian. > > Any ideas or suggestions as to how to remove this adhesive? <sigh> > Fulltiming in a 1993 Wanderlodge WB40 [Non-text portions of this message have been removed] |
08-25-2007, 13:18
I don't know about later model coaches. My coach has a fiberglass shower which
means gel coat, just like a boat. Silicone can be nasty. The solvent I use to clean up when applying Silicone is Denatured Alcohol. I rarely use silicone, many other sealants are far more efficient. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Saturday, August 25, 2007 8:01 PM Subject: Re: [WanderlodgeForum] Hpw To Remove Silicone Adhesive from Shower Walls? Don't rule out Corian ... I think my shower walls (in my '95) are made of the stuff. The silicone adhesive/caulk is difficult to remove, but a single edge razor blade in a flat holder is often able to do the trick. I'v also seen scrapers in the hardware store that hold a utility knife (trapezoidal) blade. These are somewhat more robust than the razor blades. Hardware stores sell a variety of "adhesive solvents" for various products ... but they require testing on a bit of the wall material to ensure that it won't damage it. I'd go with the mechanical (scraping) solution first -- then look for solvents only as a last resort. Always be gentle, as the Corian (or other plastic material) can be easily scratched. If the walls are Corian, they can be restored by much polishing, if you scratch while removing the silicone. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Aug 25, 2007, at 2:54 PM, Jack and Liz Pearce wrote: > Howdy, WanderlodgeForum family. > > After bumping it for the umteenth time, Jack removed a soap dispenser > from our shower wall. Underneath the backing plate of this > dispenser was > some sort of silicone adhesive. It is clear and I can pick it off in > teeny, tiny pieces. That is not very efficient. We are not sure what > material the shower walls are, either. Don't think that they are > Corian. > > Any ideas or suggestions as to how to remove this adhesive? <sigh> > Fulltiming in a 1993 Wanderlodge WB40 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
