Dometic refir not cooling well
09-08-2007, 23:57
Post: #31
Pete,
Reduced the setting to "3" after getting to 25 degrees on "5". Now,
on the "3" setting, reefer stays around 38-40 degrees.
-Shane
--- In WanderlodgeForum@yahoogroups.com, Peter T. Arnold wrote:
> On Sun, 02 Sep 2007 21:41:18 -0000, you wrote:
> >Scott,
> > I added 2 12V fans to the back compartment which blow across the
> >evaporator coils. They dropped my temp in the 'fridge from 45-50 to
> >around 25 degrees when the setting is on "5". It was a cheap fix and
> >has worked great for the past few months. Bob Robinson and John Finn
> >had similar setups and were kind enough to share the idea with me at
> >OshKosh.
> >Shane Fedeli
> >85PT40
> >Hershey, PA
> Why would you want to freeze water in your fridge? Does'nt that make
> the beer hard to drink?
> Regards,
> Pete Arnold
> You only need two things in life.......
> Duct tape and WD40
> If it moves and shouldn't...use the duct tape.
> If it doesn't move and should...use the WD40!
