Alternator Conversion from N Type to P Type
10-02-2007, 16:59
Has anyone done a conversion on the Delco alternators on our coaches
to convert them from N Type to P Type by removing the internal regulator and tri-diodes? If so, how much effort was involded? I am going to an external three stage Xantrex/Balmar (they are basically the same unit) alternator regulator as we replace all our batteries in the coach. Which will require the alternators be converted to pull out the internal regulators and bring one of the brushe outputs outside the alternator to act as the field to the external regulator. Michael Brundridge 92 WB40 Georgetown, TX |
