Would this make a good toad? Wondering about the automatic?
10-16-2007, 09:57
89 Chevrolet Blazer 2 Dr.
4.3L V-6 w/EFI
Automatic Transmission w/OD
Jon
Rebel Bird
10-16-2007, 10:14
The first place to look is the owner's manual. It should have
instructions if the vehicle needs to be towed.
Depending on what you find in the manual, the second place to go is
Remcotowing.com to look up what, if any, towing appliances are
available for that vehicle. It's possible to have a drive line
disconnect or a lubrication pump for the transmission.
Generally, a toad must have the key in the "ACC" position to unlock
the steering wheel. Some vehicles require pulling a fuse (or two) to
avoid running down the battery. You'll need to check that, as well.
Pete Masterson
aeonix1@...
On the road at Idaho Falls, CO
> 4.3L V-6 w/EFI
> Jon
> Rebel Bird
