Hooking up a aux. compressor
05-16-2005, 07:38
Where does one tie in a hookup for a auxially compressor. I'd like to
do this for the purpose of keeping air to the bus while trying to find a very slow air leak while the bus is not running. Also what should one regulate to, the pressure of the incoming air. Steve Creger 1982 FC35 Littleton,Co. |
05-16-2005, 07:42
I have an inlet in the compartment below the pass seat that went to an
electric compressor. Al S. 1981 31' fc Now in Spokane _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of stevecreger Sent: Monday, May 16, 2005 12:38 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Hooking up a aux. compressor Where does one tie in a hookup for a auxially compressor. I'd like to do this for the purpose of keeping air to the bus while trying to find a very slow air leak while the bus is not running. Also what should one regulate to, the pressure of the incoming air. Steve Creger 1982 FC35 Littleton,Co. _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed] |
05-16-2005, 07:44
On an '82 FC I'd suggest tying into the wet-tank (curb-side behind the
front axle) output. There is a tee on the rear of the tank, with a shraeder valve, you can attach there, and use a check-valve to ensure that air can't leak out through your compressor connection. Any pressure between 80psi and 120psi will be fine. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "stevecreger" wrote: > Where does one tie in a hookup for a auxially compressor. I'd like to > do this for the purpose of keeping air to the bus while trying to find > a very slow air leak while the bus is not running. Also what should one > regulate to, the pressure of the incoming air. > > Steve Creger > 1982 FC35 > Littleton,Co. |
05-16-2005, 13:46
A year ago, I executed exactly as Jeff described below. Has worked like a
pro. I mounted the compressor in the basement compartment just in front of the LR wheel where the battery boilers uste to be housed. Ran a copper line from there to Jeff's hook up point, and put a valve in the line by the compressor so could run air tools off the compressor without airing up the bus. dandarst86fc35rbhuntleyil. >From: "Jeff Miller" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Hooking up a aux. compressor >Date: Mon, 16 May 2005 19:44:55 -0000 > >On an '82 FC I'd suggest tying into the wet-tank (curb-side behind the >front axle) output. There is a tee on the rear of the tank, with a >shraeder valve, you can attach there, and use a check-valve to ensure >that air can't leak out through your compressor connection. Any >pressure between 80psi and 120psi will be fine. > > - Jeff Miller >http://www.wanderlodge.net >http://www.millercoachworks.com > > >--- In WanderlodgeForum@yahoogroups.com, "stevecreger" >wrote: > > Where does one tie in a hookup for a auxially compressor. I'd like to > > do this for the purpose of keeping air to the bus while trying to >find > > a very slow air leak while the bus is not running. Also what should >one > > regulate to, the pressure of the incoming air. > > > > Steve Creger > > 1982 FC35 > > Littleton,Co. > > |
05-17-2005, 06:17
Dan - What make/model compressor did you install?
Thanks Bob Griesel '84 FC31 WLII WA >--- In WanderlodgeForum@yahoogroups.com, "Dan Darst" wrote: > A year ago, I executed exactly as Jeff described below. Has worked like a > pro. I mounted the compressor in the basement compartment just in front of > the LR wheel where the battery boilers uste to be housed. Ran a copper line > from there to Jeff's hook up point, and put a valve in the line by the > compressor so could run air tools off the compressor without airing up the > bus. > > dandarst86fc35rbhuntleyil. > > >From: "Jeff Miller" > >Reply-To: WanderlodgeForum@yahoogroups.com > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Re: Hooking up a aux. compressor > >Date: Mon, 16 May 2005 19:44:55 -0000 > > > >On an '82 FC I'd suggest tying into the wet-tank (curb-side behind the > >front axle) output. There is a tee on the rear of the tank, with a > >shraeder valve, you can attach there, and use a check-valve to ensure > >that air can't leak out through your compressor connection. Any > >pressure between 80psi and 120psi will be fine. > > > > - Jeff Miller > >http://www.wanderlodge.net > >http://www.millercoachworks.com > > > > > >--- In WanderlodgeForum@yahoogroups.com, "stevecreger" > >wrote: > > > Where does one tie in a hookup for a auxially compressor. I'd like to > > > do this for the purpose of keeping air to the bus while trying to > >find > > > a very slow air leak while the bus is not running. Also what should > >one > > > regulate to, the pressure of the incoming air. > > > > > > Steve Creger > > > 1982 FC35 > > > Littleton,Co. > > > > |
05-17-2005, 06:51
It is a porter cable mushroom 4 gallon tank set to hit 135 psi factory spec.
No oil maintenance on the compressor. I had to modify its configuration. The motor and compressor were mounted on top of the tank. Would not fit into my basement. So fabbed a steel plate to mount to the bottom of the tank and stuck out from tank far enough to remount motor and compressor next to tank. dandarst86fc35rbhuntleyil. >From: "freewill2008" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Hooking up a aux. compressor >Date: Tue, 17 May 2005 18:17:55 -0000 > >Dan - What make/model compressor did you install? > >Thanks >Bob Griesel '84 FC31 WLII WA > > >--- In WanderlodgeForum@yahoogroups.com, "Dan Darst" >wrote: > > A year ago, I executed exactly as Jeff described below. Has worked >like a > > pro. I mounted the compressor in the basement compartment just in >front of > > the LR wheel where the battery boilers uste to be housed. Ran a >copper line > > from there to Jeff's hook up point, and put a valve in the line by >the > > compressor so could run air tools off the compressor without airing >up the > > bus. > > > > dandarst86fc35rbhuntleyil. > > > > >From: "Jeff Miller" > > >Reply-To: WanderlodgeForum@yahoogroups.com > > >To: WanderlodgeForum@yahoogroups.com > > >Subject: [WanderlodgeForum] Re: Hooking up a aux. compressor > > >Date: Mon, 16 May 2005 19:44:55 -0000 > > > > > >On an '82 FC I'd suggest tying into the wet-tank (curb-side behind >the > > >front axle) output. There is a tee on the rear of the tank, with a > > >shraeder valve, you can attach there, and use a check-valve to >ensure > > >that air can't leak out through your compressor connection. Any > > >pressure between 80psi and 120psi will be fine. > > > > > > - Jeff Miller > > >http://www.wanderlodge.net > > >http://www.millercoachworks.com > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "stevecreger" > > > >wrote: > > > > Where does one tie in a hookup for a auxially compressor. I'd >like to > > > > do this for the purpose of keeping air to the bus while trying >to > > >find > > > > a very slow air leak while the bus is not running. Also what >should > > >one > > > > regulate to, the pressure of the incoming air. > > > > > > > > Steve Creger > > > > 1982 FC35 > > > > Littleton,Co. > > > > > > > > |
