SP36 front heaters
04-23-2008, 05:25
SP36 front heaters
The only way I can avoid being roasted in the cockpit during the summer
is to turn off the valve near the engine that controls coolant flow to the front heaters. Are the heaters controlled by Sporlan valves and if so, where are they located and what kind of a job is it to replace them? Thanks. Chuck Harrison 90 SP36 Akron, Ohio |
04-23-2008, 06:45
SP36 front heaters
Have a look for heater control valves old style the are used to
control with the temperature control they are probably seized if necessary it is a kysor part you should be able to regulate the heat from inside with out closing the valve manually Stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > The only way I can avoid being roasted in the cockpit during the summer > is to turn off the valve near the engine that controls coolant > flow to the front heaters. Are the heaters controlled by > Sporlan valves and if so, where are they located and what kind of > a job is it to replace them? > > Thanks. > > Chuck Harrison > 90 SP36 > Akron, Ohio > |
04-23-2008, 06:59
SP36 front heaters
Stephen I have the same problem with my 1993 PT 40
1993 PT-40 From: Have a look for heater control valves old style the are used to control with the temperature control they are probably seized if necessary it is a kysor part you should be able to regulate the heat from inside with out closing the valve manually Stephen 77fc35 dupreeproducts. --- In "WanderlodgeForum%40yahoogroups.com", "williamcharrison" > > The only way I can avoid being roasted in the cockpit during the summer > is to turn off the valve near the engine that controls coolant > flow to the front heaters. Are the heaters controlled by > Sporlan valves and if so, where are they located and what kind of > a job is it to replace them? > > Thanks. > > Chuck Harrison > 90 SP36 > > |
04-23-2008, 07:53
SP36 front heaters
Gardner, my wife use to get roasted, also. Come to find out, the insulation on the doghouse had a void in it.
Ernie Ekberg 83PT40 Livingston, Montana Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. |
04-23-2008, 09:59
SP36 front heaters
give me a call and we'll see if we cant find the parts
Stephen 77fc35 905 328 0162 --- In WanderlodgeForum@yahoogroups.com, "smquandt" > > Stephen > > > > I have the same problem with my 1993 PT 40 have to turn off the valves at > the engine to turn off the heat. Controls don't work, do you have any parts > to fix?? > > > > Steve Quandt > > 1993 PT-40 > > Iron Mountain, MI > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Stephen Birtles > Sent: Wednesday, April 23, 2008 1:45 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: SP36 front heaters > > > > Have a look for heater control valves old style the are used to > control with the temperature control they are probably seized > if necessary it is a kysor part > you should be able to regulate the heat from inside with out closing > the valve manually > Stephen 77fc35 > dupreeproducts.com > > --- In WanderlodgeForum@ > yahoogroups.com, "williamcharrison" > > > > > The only way I can avoid being roasted in the cockpit during the summer > > is to turn off the valve near the engine that controls coolant > > flow to the front heaters. Are the heaters controlled by > > Sporlan valves and if so, where are they located and what kind of > > a job is it to replace them? > > > > Thanks. > > > > Chuck Harrison > > 90 SP36 > > Akron, Ohio > > > |
04-23-2008, 10:16
SP36 front heaters
The chassis heaters on our 88 FC are controlled by three Sporlan
valves. One under the right front bumper, one under the left rear bumper, and one above the drive side front tire hidden in a bundle of hoses and wires. All needed repaired to control heat. After finding them it was relatively easy, to repair with rebuild kits purchased from Stephen. No experience and unsure of your 90 SP. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > The only way I can avoid being roasted in the cockpit during the summer > is to turn off the valve near the engine that controls coolant > flow to the front heaters. Are the heaters controlled by > Sporlan valves and if so, where are they located and what kind of > a job is it to replace them? > > Thanks. > > Chuck Harrison > 90 SP36 > Akron, Ohio > |
04-23-2008, 11:09
SP36 front heaters
I don't yet know what my '78 FC has for valves, but my wife gets
roasted on her side no matter what I do. I would hesitate to turn any valves I found, they would probably start to leak badly. Looks like I have another project to find and replace something else.. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > The chassis heaters on our 88 FC are controlled by three Sporlan > valves. > One under the right front bumper, one under the left rear bumper, and > one above the drive side front tire hidden in a bundle of hoses and > wires. All needed repaired to control heat. After finding them it was > relatively easy, to repair with rebuild kits purchased from Stephen. > No experience and unsure of your 90 SP. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > The only way I can avoid being roasted in the cockpit during the > summer > > is to turn off the valve near the engine that controls coolant > > flow to the front heaters. Are the heaters controlled by > > Sporlan valves and if so, where are they located and what kind of > > a job is it to replace them? > > > > Thanks. > > > > Chuck Harrison > > 90 SP36 > > Akron, Ohio > > > |
04-23-2008, 11:12
SP36 front heaters
There are some manual valves under the front of my 77FC35 that the previous owner showed me how to turn in order to enable or disable the flow of hot water to the heaters. They seem to do the job, albeit requiring laying on the ground and poking underneath to access
![]() Dorn Hetzel 77FC35 Hogansville, GA On Wed, Apr 23, 2008 at 7:09 PM, Gardner Yeaw <"gcyeaw@optonline.net"> wrote:
04-23-2008, 12:30
SP36 front heaters
the 77 and 78 have no sporlan just manual Valve. But if you are still
getting heat after shutting water control valve (base of Steering Column I would bet that the small valves are stuck or control cables are bad or broken Stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Gardner, my wife use to get roasted, also. Come to find out, the insulation > on the doghouse had a void in it. > > Ernie Ekberg > 83PT40 > Livingston, Montana > > > > > **************Need a new ride? Check out the largest site for U.S. used car > listings at AOL Autos. > (http://autos.aol.com/used?NCID=aolcmp00300000002851) > |
