starting batteries, house batteries
05-29-2008, 05:33
I see folks talk about separate banks of starting and house batteries, but on my 77FC35 there seems to be just one set of batteries (excluding the generator battery), am I correct in this observation?
Regards, Dorn Hetzel 77FC35 Hogansville, GA Flat Freek Campground http://www.campground.flatcreek.us |
05-29-2008, 06:07
Yes sir, my coach has 6 house batteries which start the engine and provide power to the coach. It has one separate genset battery. All charge off the inverter/charger. Works great.
Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Dorn Hetzel
05-29-2008, 06:25
My 83 PT40 had 4 6-volt batteries for everything.
I thought there were split arrangements for the 90. Leroy did that come that way, or is that another Royale feature? My 91 has three start and 8 house batteries. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX -- In WanderlodgeForum@yahoogroups.com, Leroy Eckert wrote: > > Yes sir, my coach has 6 house batteries which start the engine and provide power to the coach. It has one separate genset battery. All charge off the inverter/charger. Works great. > > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > > > > Dorn Hetzel folks talk about separate banks of starting and house batteries, but on my 77FC35 there seems to be just one set of batteries (excluding the generator battery), am I correct in this observation? > > Regards, > > Dorn Hetzel > 77FC35 > Hogansville, GA > Flat Freek Campground > http://www.campground.flatcreek.us > |
05-29-2008, 06:27
Ooops, had a separate 12V for the genset. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > My 83 PT40 had 4 6-volt batteries for everything. > > I thought there were split arrangements for the 90. Leroy did that > come that way, or is that another Royale feature? > > My 91 has three start and 8 house batteries. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > -- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > wrote: > > > > Yes sir, my coach has 6 house batteries which start the engine and > provide power to the coach. It has one separate genset battery. All > charge off the inverter/charger. Works great. > > > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > Dahlonega, GA > > > > > > > > Dorn Hetzel > folks talk about separate banks of starting and house batteries, but > on my 77FC35 there seems to be just one set of batteries (excluding > the generator battery), am I correct in this observation? > > > > Regards, > > > > Dorn Hetzel > > 77FC35 > > Hogansville, GA > > Flat Freek Campground > > http://www.campground.flatcreek.us > > > |
05-29-2008, 06:37
AFAIK, 91 was the first year that start batteries were split out. Mine is 6+1
like Leroy's. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 5/29/2008 at 6:27 PM mbulriss wrote: >> My 83 PT40 had 4 6-volt batteries for everything. >Ooops, had a separate 12V for the genset. > >Mike Bulriss >1991 WB40 "Texas Minivan" >San Antonio, TX > >--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: >> >> My 83 PT40 had 4 6-volt batteries for everything. >> >> I thought there were split arrangements for the 90. Leroy did that >> come that way, or is that another Royale feature? >> >> My 91 has three start and 8 house batteries. >> >> Mike Bulriss >> 1991 WB40 "Texas Minivan" >> San Antonio, TX >> >> -- In WanderlodgeForum@yahoogroups.com, Leroy Eckert >> wrote: >> > >> > Yes sir, my coach has 6 house batteries which start the engine and >> provide power to the coach. It has one separate genset battery. All >> charge off the inverter/charger. Works great. >> > >> > Leroy Eckert >> > 1990 WB-40 Smoke N Mirrors >> > Dahlonega, GA >> > >> > >> > >> > Dorn Hetzel >> folks talk about separate banks of starting and house batteries, but >> on my 77FC35 there seems to be just one set of batteries (excluding >> the generator battery), am I correct in this observation? >> > >> > Regards, >> > >> > Dorn Hetzel >> > 77FC35 >> > Hogansville, GA >> > Flat Freek Campground >> > http://www.campground.flatcreek.us >> > >> > > > >------------------------------------ > >Yahoo! Groups Links > > > |
05-29-2008, 07:17
I looked at another Royale that a fellow purchased recently and it is identical to mine. Bradner has a 90, I wonder how his is set up. Mine has always been that way.
Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion mbulriss <mbulriss@...> wrote:
06-01-2008, 16:35
Don,
I take this to mean my '86 PT-40's (6) batteries are supposed to be tied together, yes? I was under the impression I had (4) house batteries and (2) engine starting batteries, until I left the marker lights on all night boondocking this weekend. The engine would not crank over in the morning. Started my generator and it ran for all of 2 minutes before blowing through a brush. Double uh-oh. Was able to start the coach with the aux battery switch, but just barely. I just went out and looked at my batteries and, indeed, they are all tied together. OK, so here's a question: Given this, what type of batteries SHOULD these (6) be? Previous owner put Optima Blue Tops on there. They don't last long boondocking. I'd like to replace 'em with something better and get a battery monitor to keep an eye on state of charge. -Ryan '86 PT-40 8V92 On Thu, May 29, 2008 at 11:37 AM, Don Bradner > AFAIK, 91 was the first year that start batteries were split out. Mine is > 6+1 like Leroy's. > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > > On 5/29/2008 at 6:27 PM mbulriss wrote: > >>> My 83 PT40 had 4 6-volt batteries for everything. >>Ooops, had a separate 12V for the genset. >> >>Mike Bulriss >>1991 WB40 "Texas Minivan" >>San Antonio, TX >> >>--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: >>> >>> My 83 PT40 had 4 6-volt batteries for everything. >>> >>> I thought there were split arrangements for the 90. Leroy did that >>> come that way, or is that another Royale feature? >>> >>> My 91 has three start and 8 house batteries. >>> >>> Mike Bulriss >>> 1991 WB40 "Texas Minivan" >>> San Antonio, TX >>> >>> -- In WanderlodgeForum@yahoogroups.com, Leroy Eckert >>> wrote: >>> > >>> > Yes sir, my coach has 6 house batteries which start the engine and >>> provide power to the coach. It has one separate genset battery. All >>> charge off the inverter/charger. Works great. >>> > >>> > Leroy Eckert >>> > 1990 WB-40 Smoke N Mirrors >>> > Dahlonega, GA >>> > >>> > >>> > >>> > Dorn Hetzel >>> folks talk about separate banks of starting and house batteries, but >>> on my 77FC35 there seems to be just one set of batteries (excluding >>> the generator battery), am I correct in this observation? >>> > >>> > Regards, >>> > >>> > Dorn Hetzel >>> > 77FC35 >>> > Hogansville, GA >>> > Flat Freek Campground >>> > http://www.campground.flatcreek.us >>> > >>> >> >> >> >>------------------------------------ >> >>Yahoo! Groups Links >> >> >> > > |
06-01-2008, 17:07
There is no perfect battery for a combined bank. The engine needs a lot of CCA,
but the house needs deep-cycle. The two are not found at their best in any single battery type. Since, with 6 batteries, any type will start the engine if reasonably charged, most choose to put in deep-cycle. It is hard to beat a 6-volt golf cart battery in that application. My coach came with 6 12-volt group 24s, and the footprint of the taller 6-volt is very close, so I can fit them in. I boondock most of two months every winter, and use a lot of power to run multiple computers routers, satellite modems, etc., so I don't skimp. That means Lifeline AGMs. $120 each 18 months ago, probably more now. Someday I may decide to find a place for a couple of big starter batteries, or I may not. Hard to say. On 6/1/2008 at 9:35 PM Ryan Wright wrote: >Don, > >I take this to mean my '86 PT-40's (6) batteries are supposed to be >tied together, yes? > >I was under the impression I had (4) house batteries and (2) engine >starting batteries, until I left the marker lights on all night >boondocking this weekend. The engine would not crank over in the >morning. Started my generator and it ran for all of 2 minutes before >blowing through a brush. Double uh-oh. Was able to start the coach >with the aux battery switch, but just barely. I just went out and >looked at my batteries and, indeed, they are all tied together. > >OK, so here's a question: Given this, what type of batteries SHOULD >these (6) be? Previous owner put Optima Blue Tops on there. They don't >last long boondocking. I'd like to replace 'em with something better >and get a battery monitor to keep an eye on state of charge. > >-Ryan >'86 PT-40 8V92 > > >On Thu, May 29, 2008 at 11:37 AM, Don Bradner >wrote: >> AFAIK, 91 was the first year that start batteries were split out. Mine is >> 6+1 like Leroy's. >> >> Don Bradner >> 90 PT40 "Blue Thunder" >> Eureka, CA >> >> On 5/29/2008 at 6:27 PM mbulriss wrote: >> >>>> My 83 PT40 had 4 6-volt batteries for everything. >>>Ooops, had a separate 12V for the genset. >>> >>>Mike Bulriss >>>1991 WB40 "Texas Minivan" >>>San Antonio, TX >>> >>>--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: >>>> >>>> My 83 PT40 had 4 6-volt batteries for everything. >>>> >>>> I thought there were split arrangements for the 90. Leroy did that >>>> come that way, or is that another Royale feature? >>>> >>>> My 91 has three start and 8 house batteries. >>>> >>>> Mike Bulriss >>>> 1991 WB40 "Texas Minivan" >>>> San Antonio, TX >>>> >>>> -- In WanderlodgeForum@yahoogroups.com, Leroy Eckert >>>> wrote: >>>> > >>>> > Yes sir, my coach has 6 house batteries which start the engine and >>>> provide power to the coach. It has one separate genset battery. All >>>> charge off the inverter/charger. Works great. >>>> > >>>> > Leroy Eckert >>>> > 1990 WB-40 Smoke N Mirrors >>>> > Dahlonega, GA >>>> > >>>> > >>>> > >>>> > Dorn Hetzel >>>> folks talk about separate banks of starting and house batteries, but >>>> on my 77FC35 there seems to be just one set of batteries (excluding >>>> the generator battery), am I correct in this observation? >>>> > >>>> > Regards, >>>> > >>>> > Dorn Hetzel >>>> > 77FC35 >>>> > Hogansville, GA >>>> > Flat Freek Campground >>>> > http://www.campground.flatcreek.us >>>> > >>>> >>> >>> >>> >>>------------------------------------ >>> >>>Yahoo! Groups Links >>> >>> >>> >> >> > >------------------------------------ > >Yahoo! Groups Links > > > |
