Tricks on a re wire project
05-29-2008, 06:41
Good after noon to everyone:
I am working on my gen set and the following is the knowed up stuff:
Symptom:
Gen starts, runs 2 minutes and shuts down.
1. known facts, wire the fuel solenoid back and gen set runs with out put
also runs, the yellow light in the center of the stop start switch goes out
but I still have 110vac out put.
Conclusion: 110 vac relay CR contacts are opening, thus the light goes out
and causes the shut down sequence of 12 vdc relay 2-CR. Further conclusion;
Since 120 vac out put is present, the contacts of 110 vac relay CR are
bouncing open? Wrong relay was installed? burned or corroded contacts on
wiring or relay contacts?
Work in Progress:
1 Opened control box, checked for corrosion, yes there is.
2. Checked for proper relays; 110 vac Relay is wrong type, 12 vdc relay 1-
CR is wrong type, 12 vdc relay 2-CR and 12 vdc relay C, contacts and wiring
corroded.
3. Found part of the control box to have been re wired at one time or
other, wrong size wiring used and wiring ends should have been wicked with
solder before ring tongue connectors installed.
4. L1/L2 and Neutral wires loose on Terminal strip.
Planned completion to be done; And a suggestion to all, go to an electrical
out let and buy some wire numbers, get a bottle of alcohol and shop rags
then before pulling on wire off anything, have your book ready, and double
check wiring according to the diagram if no diagram then draw one up and
mark each wire as you remove it. Clean a spot on the wire with alcohol,
then apply a wire number, marking it down on your diagram. Never try to
remember where wires go, 3 days later they will not go to the same place in
our minds. Been there on that one.
So bottom line is, get any wiring, pneumatic, hydraulic or electronic
project done but take more extra time at the beginning. It WILL save you
time and effort in the end, and replace components as needed but with the
proper parts and not a knock off part that will only work one or two times.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
05-30-2008, 02:07
Hi Ralph,
The word is out that you are excellent on electrical repairs.
We will see you in Nov. after our workcamping here in Branson, to get
some stuff done.
Bob Lawrence
84 PT36
Workcamping in Branson Mo. for 6 months.
> Symptom:
out put
goes out
goes out
conclusion;
are
contacts on
> Work in Progress:
relay 1-
and wiring
> corroded.
or
wicked with
electrical
rags
double
up and
alcohol,
try to
place in
electronic
save you
with the
two times.
> Safe travels,
> Duncan, Oklahoma
05-30-2008, 02:52
Bob:
How do you like the Workcamping deal so far.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Bob Lawrence wrote:
Hi Ralph,
some stuff done.
Bob Lawrence
84 PT36
> Symptom:
out put
goes out
goes out
conclusion;
are
contacts on
> Work in Progress:
relay 1-
and wiring
corroded.
or
wicked with
electrical
rags
double
up and
alcohol,
try to
place in
electronic
save you
with the
two times.
> Safe travels,
> Duncan, Oklahoma
