Finding Competant Mobile Mechanics
06-23-2008, 00:32
A thought on finding a mobile Mechanic. Our firehouse uses a fellow who is very good, use to working in adverse conditions. You might ask at your local firehouse, not applicable in a big city. Pete |
A field tech should be able to remove the cold side valve cover ,then you can move the throttle by hand to see if the fuel rack on the cold side is moving since none of them appear to be firing, I would think no fuel or the rack control rod has come loose and not moving the injectors. Just a though,
RE -------------- Original message from "Gregory OConnor" |
