Generator wiring
06-26-2008, 04:17
Generator wiring
I just purchased a 1980 FC33 and it's a bit of a project. The
original genset has been removed. A prior owner started to install a Onan Marquis Gold 7kW unit. The 120V wiring is hooked up, but all the 12V stuff is just a mess. Nothing labeled, loose wirenuts, etc. No starting battery has been installed yet. I have just put in a ground for the genset and pos/neg battery cables. My unidentified wires are: 1) 2 reds joined with a wire nut in one loom 2) 2 greens just loose with exposed ends in another loom 3) one orange with a small ring terminal and a much longer purple (or maybe brown) with a broken off terminal in their own loom 4) one big black battery cable that does not have continuity to ground or voltage from either the charger or the battery bank Things I know are disconnected are the microswitch for the door lock indicator, the oil pressure and temp gauges (and the hour meter but I thought that worked off one of the other leads.) There does not seem be be a hot wire for battery charging present. Air slide cylinder is absent and the hose is just kinked off. Anyone able to identify which wires go where? An original wiring diagram or picture of the factory installation would be helpful. John Churchill Sanibel, FL |
