front air bags
09-16-2008, 15:14
front air bags
started the bird today and the front air bags will not come all the way
up.will rise about 1 inch and stop. rear bags come up just fine. iam thinking it the leveling valve on the front axel. anyone have any ideas as to what it might be. will look at the valve and see if needs to be rebuilt and or cleaned. chime in with your ideas. thanks for any help you can offer. ed mcstay "lonesome dove" 83fc rb 35ft |
09-17-2008, 12:30
front air bags
Ed,
I think you are on target looking at the valve. From what I have read the control rod is not that hefty nor is the connection on the axel. It may be as simple as re-adjusting it and insuring it is not slipping. As always, be absolutly sure the coach is properly supported (Jack stands) before going under. Gardner 83FC35 SB --- In WanderlodgeForum@yahoogroups.com, "Peggy & Ed McStay" > > started the bird today and the front air bags will not come all the way > up.will rise about 1 inch and stop. rear bags come up just fine. iam > thinking it the leveling valve on the front axel. anyone have any ideas > as to what it might be. will look at the valve and see if needs to be > rebuilt and or cleaned. chime in with your ideas. thanks for any help > you can offer. > > ed mcstay > "lonesome dove" > 83fc rb 35ft > |
06-28-2010, 11:48
front air bags
Hi group,
Can't find the numbers for the 84 PT36 air bags or the rears either. Also contacted Koni for rear shocks for the bird and got an email back stating "Sorry, can't help you" Really? Anybody got these #'s? Thanks. Bob Lawrence 84 PT36 Cushing, Maine (Workcamping for the summer) |
06-28-2010, 15:18
front air bags
Dpn Bradner sent me the following:
Front 902497SP-1 Drive 90441005 (FSD) Tag 88051010 (FSD) These are Koni numbers. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Bluebird Bob" wrote: > > Hi group, > Can't find the numbers for the 84 PT36 air bags or the rears either. > Also contacted Koni for rear shocks for the bird and got an email back stating "Sorry, can't help you" > Really? > Anybody got these #'s? > Thanks. > > Bob Lawrence > 84 PT36 > Cushing, Maine (Workcamping for the summer) > |
06-29-2010, 12:14
front air bags
Thanks, Ron.
I assume these #'s will work for my bird. Bob Lawrence 84 PT36 Cushing, Maine --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > Dpn Bradner sent me the following: > > Front 902497SP-1 > Drive 90441005 (FSD) > Tag 88051010 (FSD) > > These are Koni numbers. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "Bluebird Bob" > > > > Hi group, > > Can't find the numbers for the 84 PT36 air bags or the rears either. > > Also contacted Koni for rear shocks for the bird and got an email back stating "Sorry, can't help you" > > Really? > > Anybody got these #'s? > > Thanks. > > > > Bob Lawrence > > 84 PT36 > > Cushing, Maine (Workcamping for the summer) > > > |
06-29-2010, 12:35
front air bags
Bob, Try Justin Mc Coy at Koni 1-866-566-4175 ext 314
I met him at RIV a couple of years ago and if he is still with koni he should be able to help. My 88/38 uses a different set of numbers for the shocks but it is a WB.
Dan Williams
88WB38
Jackson, MS
06-29-2010, 12:36
front air bags
When you call Koni, ask for verification.
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Bluebird Bob" wrote: > > Thanks, Ron. > I assume these #'s will work for my bird. > > Bob Lawrence > 84 PT36 > Cushing, Maine > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > > > > > Dpn Bradner sent me the following: > > > > Front 902497SP-1 > > Drive 90441005 (FSD) > > Tag 88051010 (FSD) > > > > These are Koni numbers. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com, "Bluebird Bob" wrote: > > > > > > Hi group, > > > Can't find the numbers for the 84 PT36 air bags or the rears either. > > > Also contacted Koni for rear shocks for the bird and got an email back stating "Sorry, can't help you" > > > Really? > > > Anybody got these #'s? > > > Thanks. > > > > > > Bob Lawrence > > > 84 PT36 > > > Cushing, Maine (Workcamping for the summer) > > > > > > |
