Dingy Odometer Reading
05-28-2005, 06:22
I am going to tow a dingy for the first time next week and am
wondering if there is any way to keep the odometer from recording the towed mileage. The car I will be towing is a 1990 Acura Legend. Roy Anderson Springfield VA 1986 PT-40 |
05-28-2005, 08:28
Roy,
According to my factory Acura information system, the power for the speedometer comes through fuse #9 in the dash fuse box, which is hopefully powered by the ignition switch. If the ignition switch is off, the speedometer doesn't work. If it's an automatic, do you know "the procedure" for towing it without transmission damage? George Witt 81 FC 35 Lincoln, Nebraska--Huskers http://www.georgewitt.com Honda/Acura Specialist Repair Shop Also servicing Toyota/Lexus (Shameless self-promotion) ;o) --- In WanderlodgeForum@yahoogroups.com, "snowbirdtogo" wrote: > I am going to tow a dingy for the first time next week and am > wondering if there is any way to keep the odometer from recording the > towed mileage. The car I will be towing is a 1990 Acura Legend. > Roy Anderson > Springfield VA > 1986 PT-40 |
05-28-2005, 10:28
George, Thankyou for reply. I checked fuse box but it doesn't number the fuses and none of the descriptions for what the fuse controls indicates speedometer. I assume it is a Federal thing to avoid tampering with odometer reading. But that gives me a direction to go so I will have to try pulling and test driving till I get the right one. Roy Anderson Springfield VA 1986 PT-40 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of mrdonut12 Sent: Saturday, May 28, 2005 4:28 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Dingy Odometer Reading Roy, According to my factory Acura information system, the power for the speedometer comes through fuse #9 in the dash fuse box, which is hopefully powered by the ignition switch. If the ignition switch is off, the speedometer doesn't work. If it's an automatic, do you know "the procedure" for towing it without transmission damage? George Witt 81 FC 35 Lincoln, Nebraska--Huskers http://www.georgewitt.com Honda/Acura Specialist Repair Shop Also servicing Toyota/Lexus (Shameless self-promotion) ;o) --- In WanderlodgeForum@yahoogroups.com, "snowbirdtogo" wrote: > I am going to tow a dingy for the first time next week and am > wondering if there is any way to keep the odometer from recording the > towed mileage. The car I will be towing is a 1990 Acura Legend. > Roy Anderson > Springfield VA > 1986 PT-40 _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms of <http://docs.yahoo.com/info/terms/> Service. [Non-text portions of this message have been removed] |
