Bizarre - Masters degree credit available for alternator cha...
11-14-2008, 14:28
I doubt if there are many bird owners that don't believe theirs has
a "soul" but I find this really spooky. THE VERY NEXT TIME I started "Gerald" after making the original post, the alternator showed charge WITHOUT the throttle rev. Two times now !!! WHHHOOOOOOOOOWWWWW, and it isn't even Halloween, GPSGary |
11-14-2008, 14:40
Oh, on the contrary... Soul is what Wanderlodge ownership is all about! David Brady '02 LXi, NC hippieforever3 wrote:
11-14-2008, 15:17
David,
Since I don't have an advanced degree, can you answer a question for me? What's the difference between the "engine pre-heat" switch over the driver's head and the lighted pre-heat switch in front of the sink? It's cold here in Texas tonight. I have Aqua-Hot on but I don't plan to run the Webasto. Brad Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@yahoogroups.com From: dmb993@... Date: Fri, 14 Nov 2008 21:40:48 -0500 Subject: Re: [WanderlodgeForum] Bizarre - Masters degree credit available for alternator cha...
Stay up to date on your PC, the Web, and your mobile phone with Windows Live Click here |
11-14-2008, 15:32
Hi Brad,
No advanced degree required. The switch above the pilot seat turns on the engine Aqua-hot preheat pump (requires that the Aqua-hot be running, electric or diesel), and the switch by the sink is for the electric heat element screwed directly into the S-60 block, this heat is only available with shore power. Stay warm down there; hey, what am I talking about, we're currently in frigid North Carolina! David Brady '02 LXi, NC --- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...> wrote: > > > David, > Since I don't have an advanced degree, can you answer a question for me? > What's the difference between the "engine pre-heat" switch over the driver's head and the lighted pre-heat switch in front of the sink? It's cold here in Texas tonight. I have Aqua-Hot on but I don't plan to run the Webasto. > BradBrad Barton 00LXiDFW bbartonwx@... > > > > To: WanderlodgeForum@...: dmb993@...: Fri, 14 Nov 2008 21:40:48 -0500Subject: Re: [WanderlodgeForum] Bizarre - Masters degree credit available for alternator cha... > > > > Oh, on the contrary... Soul is what Wanderlodge ownership isall about!David Brady'02 LXi, NChippieforever3 wrote: > > > I doubt if there are many bird owners that don't believe theirs has a "soul" but I find this really spooky.THE VERY NEXT TIME I started "Gerald" after making the original post, the alternator showed charge WITHOUT the throttle rev.Two times now !!!WHHHOOOOOOOOOWWWWW, and it isn't even Halloween,GPSGary > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.549 / Virus Database: 270.9.3/1786 - Release Date: 11/13/2008 6:01 PM > > > > > > > > _________________________________________________________________ > Stay up to date on your PC, the Web, and your mobile phone with Windows Live > http://clk.atdmt.com/MRT/go/119462413/direct/01/ > |
11-14-2008, 15:39
I suppose I could run the Aqua-hot all night, but not the block heater.
Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@yahoogroups.com From: dmb993@... Date: Sat, 15 Nov 2008 03:32:27 +0000 Subject: [WanderlodgeForum] Re: Bizarre - Masters degree credit available for alternator cha...
Hi Brad, No advanced degree required. The switch above the pilot seat turns on the engine Aqua-hot preheat pump (requires that the Aqua-hot be running, electric or diesel), and the switch by the sink is for the electric heat element screwed directly into the S-60 block, this heat is only available with shore power. Stay warm down there; hey, what am I talking about, we're currently in frigid North Carolina! David Brady '02 LXi, NC --- In "WanderlodgeForum@yahoogroups.com", brad barton <bbartonwx@.<WBR>..> wrote: > > > David, > Since I don't have an advanced degree, can you answer a question for me? > What's the difference between the "engine pre-heat" switch over the driver's head and the lighted pre-heat switch in front of the sink? It's cold here in Texas tonight. I have Aqua-Hot on but I don't plan to run the Webasto. > BradBrad Barton 00LXiDFW bbartonwx@.. > > > > To: WanderlodgeForum@ -0500Subject: Re: [WanderlodgeForum] Bizarre - Masters degree credit available for alternator cha... > > > > Oh, on the contrary... Soul is what Wanderlodge ownership isall about!David Brady'02 LXi, NChippieforever3 wrote: > > > I doubt if there are many bird owners that don't believe theirs has a "soul" but I find this really spooky.THE VERY NEXT TIME I started "Gerald" after making the original post, the alternator showed charge WITHOUT the throttle rev.Two times now !!!WHHHOOOOOOOOOWWW isn't even Halloween,GPSGary > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.549 / Virus Database: 270.9.3/1786 - Release Date: 11/13/2008 6:01 PM > > > > > > > > ____________ > Stay up to date on your PC, the Web, and your mobile phone with Windows Live > http://clk.atdmt. > Get 5 GB of storage with Windows Live Hotmail. Sign up today. |
11-14-2008, 16:24
Many people who live in the north never winterize there coaches; they simply run their A-H's continuously from December to April. David Brady brad barton wrote:
11-15-2008, 02:29
Switch on the panel over the driver's side window: "Engine Preheat"
-- this activates the AquaHot engine coolant link to warm the coolant. You must ALSO have the "hydronic heat" switch ON (located on the main dashboard array, upper left quadrant on my coach). This allows the AquaHot to fire up the diesel burner. If the hydronic heat switch is off, the 2000 watt electrical element in the AquaHot may provide a very modest bit of heating as might be needed in cool rather than truly cold conditions. When the AquaHot burner is operating, it is very effective and, depending on how cold it gets, will warm the engine for startup in 30 minutes to 2 hours. Switch in front of the sink (usually a red, lighted switch). This is the engine block heater. It has a heating element installed on or in the engine that directly heats the engine block (or possibly the oil pan). [I haven't investigated exactly where it's located or the exact type of installation on my 'Bird.] It's much slower than the "Engine Preheat" -- usually it's advisable to turn it on at least 12 hours before a planned startup. It may prove insufficient in really cold weather (in my experience) but it's better than nothing. When I use mine, I usually turn it on around dinner time the night before a travel day. Note that both engine heater systems MUST be turned off when the engine is running, as either (or worse both together) can overwhelm the cooling system causing overheating and possible engine damage if they remain on. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart, Texas -- where it will be cold tonight, too... On Nov 14, 2008, at 9:17 PM, brad barton wrote: > David, > Since I don't have an advanced degree, can you answer a question > for me? > What's the difference between the "engine pre-heat" switch over the > driver's head and the lighted pre-heat switch in front of the > sink? It's cold here in Texas tonight. I have Aqua-Hot on but I > don't plan to run the Webasto. > Brad > > Brad Barton 00LXiDFW bbartonwx@... > |
11-16-2008, 16:27
Thanks Pete and David.
I thought the block heater might scorch the oil if it was left on too long. I ran the pre-heat from Aqua-Hot just on AC. It got to 40last night just outside New Braunfels. I usually hit the Webasto before the morning showers to give the hot water a boost. BTW, the Walnut Canyon RV Park on 2763 is more for fifth wheels than 43' coaches. And the bathhouse was 'prison primitive' with the rope-activated spring-loaded non-adjustable temperature shower. And the well water smelled of sulphur. Nice folks but not the park for us. Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@yahoogroups.com From: aeonix1@... Date: Sat, 15 Nov 2008 08:29:39 -0600 Subject: Re: [WanderlodgeForum] Bizarre - Masters degree credit available for alternator cha...
Switch on the panel over the driver's side window: "Engine Preheat" -- this activates the AquaHot engine coolant link to warm the coolant. You must ALSO have the "hydronic heat" switch ON (located on the main dashboard array, upper left quadrant on my coach). This allows the AquaHot to fire up the diesel burner. If the hydronic heat switch is off, the 2000 watt electrical element in the AquaHot may provide a very modest bit of heating as might be needed in cool rather than truly cold conditions. When the AquaHot burner is operating, it is very effective and, depending on how cold it gets, will warm the engine for startup in 30 minutes to 2 hours. Switch in front of the sink (usually a red, lighted switch). This is the engine block heater. It has a heating element installed on or in the engine that directly heats the engine block (or possibly the oil pan). [I haven't investigated exactly where it's located or the exact type of installation on my 'Bird.] It's much slower than the "Engine Preheat" -- usually it's advisable to turn it on at least 12 hours before a planned startup. It may prove insufficient in really cold weather (in my experience) but it's better than nothing. When I use mine, I usually turn it on around dinner time the night before a travel day. Note that both engine heater systems MUST be turned off when the engine is running, as either (or worse both together) can overwhelm the cooling system causing overheating and possible engine damage if they remain on. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 "aeonix1@mac.com" On the road at Lockhart, Texas -- where it will be cold tonight, too... On Nov 14, 2008, at 9:17 PM, brad barton wrote: > David, > Since I don't have an advanced degree, can you answer a question > for me? > What's the difference between the "engine pre-heat" switch over the > driver's head and the lighted pre-heat switch in front of the > sink? It's cold here in Texas tonight. I have Aqua-Hot on but I > don't plan to run the Webasto. > Brad > > Brad Barton 00LXiDFW "bbartonwx@hotmail.com" > Stay up to date on your PC, the Web, and your mobile phone with Windows Live Click here |
11-17-2008, 07:38
11-17-2008, 11:39
Thanks, Wallace.
We don't get out much but once we do, your idea sounds like the only way to go. Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@yahoogroups.com From: wallacecraig1@... Date: Mon, 17 Nov 2008 11:38:41 -0800 Subject: RE: [WanderlodgeForum] Bizarre - Masters degree credit available for alternator cha...
Windows Live Hotmail now works up to 70% faster. Sign up today. |
