Holding Tank capacities
01-12-2009, 16:52
Hi all,
looking to find out the gray and black water tank capacities on our
74/FC-31. I have found information on FC-77 and 78, but those were all
35 footers. Since we carry 60 gallons of water I'm thinking 40 gallons
gray and 30 gallons black.
any thoughts on it?
thanks as always.
Jim Benson
74-FC-31
Mai Tai Fine
01-12-2009, 18:13
if you have a dump place at home you can use the city meter to calc the
at full capacity. 10 cu feet used =74.81 gallons. each cubic foot is
7.481 gallons. or 1 gallon is .1338 of a cubic foot. the water meter is
way accurate and usuly have a drip triangl on the dial to show minor
flow passing the meter, helpful to detect a minor leak
Gregory 'ofTim&Greg
94ptCa
--- In WanderlodgeForum@yahoogroups.com, "Jim Benson"
> Hi all,
> any thoughts on it?
> thanks as always.
> Jim Benson
> 74-FC-31
> Mai Tai Fine
01-14-2009, 13:56
If you want to calculate the volume of your gray and black tank one
way to do it is:
Bring a hose into your shower. It is nice to have a shut off valve at
the end of the hose. Let the water flow. A modest stream is best.
Leave your gray tank open to drain.
Time exactly the time it takes to fill a five gallon bucket. Be
exact. You can now calculate the flow rate in gallons per minute or
seconds. (Dump the five gallon bucket in the shower.) Do not shut
off the water on the hose or change the flow rate.
Now close your gray tank valve. Note the time. Go back to the shower
room. As soon as you see the water in the shower floor start to back
up, note the time and shut off the water.
You now know the flow rate out of the hose in gallons per minute and
the number of minutes it took to fill your gray tank. Multiply these
two numbers and you will get the volume of your gray tank.
You can do the same calculations with your black tank but it's hard to
do it without getting some water on the floor of your bathroom. I
used two five gallon buckets. One to start the flow of water, once
steady I moved the hose to the second bucket that I timed how long it
took to fill the five gallon bucket. Then switched back to the first
bucket. You then time how long it takes to fill the black tank,
multiply the result by the flow rate and you have the volume of your
black tank.
01-14-2009, 14:11
Jim Benson
From some of the looking around I have had time to do,it seems your guess is about correct.
40 gray & 30 black
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
