Battery life while dry camping
03-13-2009, 04:14
I know this is a little oft the wall but does anyone have an idea how long a set
of new batterys should last while dry camping? I would just use the electrical part of the coach very minimally. Jon |
03-13-2009, 05:23
Jon,
That's not off the wall, it's a viable question I'm very lucky to have 12volts after 24hrs without charging. This would be accomplished only with nothing running, except the ghost 5amp? draw inherent to all Wanderlodges I've heard of. We run the gen-set at least 1.5-2hrs twice a day. This affords us minimal lights and enough TV, and laptop time. To run like this it costs about a gallon or less of Diesel a day. My setup includes 6-6volt batteries[rated at 240ah-20hrs,or 195ah-5hrs], these batteries are equivalent to Trojan 125's one size bigger than the Torjan 105's, same footprint and 2"taller than the 105's. And 2-IOTA 45a chargers with an iota smart controller in line. Harold Prescott 1985 WLFC35 Joshua Tree np, CA. Homeward Bound --- In WanderlodgeForum@yahoogroups.com, "Jon" > > I know this is a little oft the wall but does anyone have an idea how long a set of new batterys should last while dry camping? I would just use the electrical part of the coach very minimally. Jon > |
03-13-2009, 05:25
Way too many variables to answer that Jon. Number of batteries, battery type,
load type, etc... However, if you read through this ariticle (kind of a battery bible) you will understand more than you ever wanted to know. http://www.phrannie.org/battery.html Basically, to give you and example, if you had a 100 ah lead-acid deep cycle battery you'd first derate it 25% to 75 ah. A 75 amp hour battery means you can draw 1 amp for 75 hours or 5 amps for 15 hours basically, but it is not that simple as the ratings really are not linear. And you never want to discharge beyound 50% of the battery's rating. So now your 75 ah is down to 37.5 ah. So you could run a heater that draws 5 amps for about 6-7 hours continuously before the battery needed to be recharged. But fortunately they usually don't run continuously but just wanted to give some example of how to guestimate your needs. The best method is to work backwards. Figure out everything you'll be running, get an amp draw, then caculate how many batteries you'll need for that requirement. Read through the battery site and you'll learn a lot and have more questions I'm sure... Michael 78FC35 Mesa, Az --- In WanderlodgeForum@yahoogroups.com, "Jon" > > I know this is a little oft the wall but does anyone have an idea how long a set of new batterys should last while dry camping? I would just use the electrical part of the coach very minimally. Jon > |
03-13-2009, 18:39
Charge during times of high use. At Q FredH would run the genset just prior to
Margarita hour and after his morning shower (4frick'n:30am). I don't drink stuff with chopped ice or blow dry so I can go 4 days Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Jon" > > I know this is a little oft the wall but does anyone have an idea how long a set of new batterys should last while dry camping? I would just use the electrical part of the coach very minimally. Jon > |
03-14-2009, 15:15
That's Pepsi hour Greg
And it was ( 5frick'n am)
FredH
of Fred & Jeanne
03-15-2009, 12:53
Greg was on Calif. time...
Curt Sprenger On Sat, Mar 14, 2009 at 7:15 PM, Fred Hulse <"fhulse@wildblue.net"> wrote:
03-15-2009, 13:27
Curt
You are so right,
I had forgotten about the time was an hour earlier 18 miles to the west and he was in that time period.
Geez!
My mistake.
(5 frickin30 it is)
Fred H
of Fred & Jeanne
On mountain standard time
03-17-2009, 16:43
If I am slightly careful I can get by with running the generator once a day for
2 hours +/-. I don't like being careful, so I usually charge the batteries twice a day for 1 to 3 hours. To determine how long you can go with your lifestyle and batteries you have you must monitor the voltage on your batteries. In a hyper condensed summary: You don't want to have the capacity drop below 50%. When you are dry camping monitor your batteries several times a day with a digital voltmeter. When you hit the 50% charge level it's time to recharge your batteries. (It's 12.05 volts on my AGM batteries.) If you keep doing this you will eventually learn what your recharging point should be, which will depending on your lifestyle and battery capacity. Note: This issue is MUCH more complicated that this. You should research this issue. It is quite uncomfortable to live on your batteries and not know if you are abusing them. Here's a couple of links: http://www.phrannie.org/battery.html http://www.amplepower.com/primer/index.html Incidentally, in the future it would be helpful if you sign your post along with the year and type of coach you drive. Some people may know you but likely most do not. It's often hard to respond without that information. Eric Perplies 96' 42' WBWL currently in Gallup, NM |
03-18-2009, 01:24
--- In WanderlodgeForum@yahoogroups.com, "Eric Perplies"
> > If I am slightly careful I can get by with running the generator once a day for 2 hours +/-. I don't like being careful, so I usually charge the batteries twice a day for 1 to 3 hours. > > To determine how long you can go with your lifestyle and batteries you have you must monitor the voltage on your batteries. In a hyper condensed summary: You don't want to have the capacity drop below 50%. When you are dry camping monitor your batteries several times a day with a digital voltmeter. When you hit the 50% charge level it's time to recharge your batteries. (It's 12.05 volts on my AGM batteries.) If you keep doing this you will eventually learn what your recharging point should be, which will depending on your lifestyle and battery capacity. > > Note: This issue is MUCH more complicated that this. You should research this issue. It is quite uncomfortable to live on your batteries and not know if you are abusing them. Here's a couple of links: > > http://www.phrannie.org/battery.html > http://www.amplepower.com/primer/index.html > > Incidentally, in the future it would be helpful if you sign your post along with the year and type of coach you drive. Some people may know you but likely most do not. It's often hard to respond without that information. > > Eric Perplies > 96' 42' WBWL > currently in Gallup, NM I always enjoy spending other people's money, so if you really wanrt to know about your batteries, there are pretty high tech monitoring systems available incorporating charger/inverter and monitor. Xantrex is one brand name. John Churchill 1980 FC33 Sanibel FL > |
