					batery saver switch
					06-07-2005, 01:04
				 Post: #11 | |||
| batery saver switch
					Glenn, What was the date on that bulletin? Mark, 80FC35 in PA --------------------------------- Discover Yahoo! Get on-the-go sports scores, stock quotes, news & more. Check it out! [Non-text portions of this message have been removed] | |||
					06-07-2005, 04:11
				 Post: #12 | |||
| batery saver switch
					Printer didn't print the whole page and the date is missing but believe it to be 1982 ----- Original Message ----- From: Mark Garber To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, June 07, 2005 8:04 AM Subject: Re: [WanderlodgeForum] batery saver switch Glenn, What was the date on that bulletin? Mark, 80FC35 in PA --------------------------------- Discover Yahoo! Get on-the-go sports scores, stock quotes, news & more. Check it out! [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] | |||
					06-08-2005, 05:30
				 Post: #13 | |||
| batery saver switch
					As originally equipped: '83 and older, one master switch under the dash ahead of driver's right knee, - turns off everything except radio memory, clocks / monitor panel, alarm, refrigerator, LP alarm/shutoff. Late '83 on, a second switch in the left overhead at the rear of the sofa, should turn off all remaining electronic loads. Some still have alarm and refrigerator power which would need to be turned off separately. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, > Send me an email. I have part of the BB bulletin that says how to install a switch that will do as we need. Also says it should have been done prior to our birds MFG. I'm in KC close to Liberty and would love to see a bird close to mine. Its the only one I've ever been around and it ain't like anything I've ever had dealings with. (SOB's) > > Glenn Shehorn > 83FC35 RB > Kansas City MO ( Tornado Alley) > > ----- Original Message ----- > From: dwalks@a... > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, June 06, 2005 4:38 PM > Subject: Re: [WanderlodgeForum] Re: batery saver switch > > > Glenn, Phil is right. On my 84fc it is just where he said. Only it doesn't > shut off everything in my bird. I shut off both master switch's, the other > being by your right knee, under the dash. > Wish I knew how I can shut off the total deal without taking a battery cable > off. > Any help on this ???????? > walker > 84FC35 > kcmo > > > [Non-text portions of this message have been removed] > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] | |||
					06-08-2005, 05:42
				 Post: #14 | |||
| batery saver switch
					The load center referenced is in the first (small) overhead cabinet forward of your galley overhead cabinets. You coach would not have (originally) had this switch, an easy install though. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "glenn_shehorn" > I found a BB Engineering bulletin that refers to a switch that shuts > off the filtered circuits that the master switch doesnt. It says to > locate it in the overhead cabinet beside the left front load center. I > havn't found this load center. Any ideas. > Glenn Shehorn > 83FC35RB > Kansas City Mo | |||
					06-08-2005, 08:50
				 Post: #15 | |||
| batery saver switch
					Thanks, there is a stereo speaker in that door and I might never have seen the latch unless I was laying on the couch looking aft and up. No switch but looks like a simple fix that should save Wally World a ton of warranty batteries, this last set brings the total to sixteen. I may be able to justify good batteries in the near future Glenn 83FC35RB Kansas City Mo ----- Original Message ----- From: Jeff Miller To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, June 08, 2005 12:42 PM Subject: [WanderlodgeForum] Re: batery saver switch The load center referenced is in the first (small) overhead cabinet forward of your galley overhead cabinets. You coach would not have (originally) had this switch, an easy install though. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "glenn_shehorn" > I found a BB Engineering bulletin that refers to a switch that shuts > off the filtered circuits that the master switch doesnt. It says to > locate it in the overhead cabinet beside the left front load center. I > havn't found this load center. Any ideas. > Glenn Shehorn > 83FC35RB > Kansas City Mo ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] | |||
					09-14-2005, 05:38
				 Post: #16 | |||
| batery saver switch
					I installed a master disconnect in the battery house, forward of the Driver steer tire. Calterm #41860 12VDC 50A from O'Reillys. simple instal. 3 holes two 1/4 20 bolts and a battery cable. About $30 Glenn Shehorn 83FC35 Kansas City Mo ----- Original Message ----- From: dwalks@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 06, 2005 4:38 PM Subject: Re: [WanderlodgeForum] Re: batery saver switch Glenn, Phil is right. On my 84fc it is just where he said. Only it doesn't shut off everything in my bird. I shut off both master switch's, the other being by your right knee, under the dash. Wish I knew how I can shut off the total deal without taking a battery cable off. Any help on this ???????? walker 84FC35 kcmo [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
