Air Bags (Springs) & Radiator order numbers
04-03-2009, 23:29
Hi,
These are the order numbers my research uncovered.
Order numbers for Air Bags and a Radiator for our 93' WL
Detroit Diesel TAC DDECII 500 HP.
Air Springs
1286814 front
0961250 rear
0990671 tag
Radaitor
G & O #x-3190-11996
We need to replace the above. Correct numbers ?
Thank You for any comments or suggestions,
Gene Sharp
93' WL 40'
Belle Center, Ohio
04-04-2009, 01:08
Those air bag numbers are BB numbers which you will need to cross. I think they are the same as mine. Ridewell Models RAS227 and RAD227. I thought I had the cross for all of them but so far follows what I have.
Steer Axel-
BB 1286814
Firestone-W01-358-9457
Goodyear 1R11-151
Ridewell-1003589457C
I know I have the others somewhere. I will keep looking.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
--- On Sat, 4/4/09, Gene Sharp wrote:
Subject: [WanderlodgeForum] Air Bags (Springs) & Radiator order numbers
Date: Saturday, April 4, 2009, 7:29 AM
Hi,
Air Springs
1286814 front
0961250 rear
0990671 tag
Radaitor
G & O #x-3190-11996
Gene Sharp
93' WL 40'
Belle Center, Ohio
04-06-2009, 23:43
Leroy,
Did they use all the same size air bags for all axles ?
Do you have the radaitor order number ?
Sorry to keep asking the same questions.
Thanks for Your Help,
Gene Sharp
93' WL 40'
Ohio
> Steer Axel-
> BB 1286814
> Goodyear 1R11-151
> Leroy Eckert
> Dahlonega, GA
> From: Gene Sharp
> Hi,
> Air Springs
> 1286814 front
> 0961250 rear
> 0990671 tag
> Radaitor
> G & O #x-3190-11996
> Gene Sharp
> 93' WL 40'
> Belle Center, Ohio
04-07-2009, 00:12
There are three different air bags/springs. The BB numbers you have are correct per my records. Follows are Ridewell numbers which I have. I still cannot find the cross for these two in my files.
Tag-BB number-0990671, 4 each
Ridewell-100-358-9073C
Drive-BB number-0961250-4each
Ridewell-100-358-9039C
http://www.ridewellcorp.com- Look under air spring part, by part number.
If I ever find the cross reference in my files, I think I will summarize and post them in the parts section of the forum.
I show the same radiator manufacturer and number. I would suggest you have a radiator shop go through yours and make it good as new. It will be a lot less expensive.
Leroy Eckert
Dahlonega,
GA
--- On Tue, 4/7/09, Gene Sharp wrote:
Subject: [WanderlodgeForum] Re: Air Bags (Springs) & Radiator order numbers
Date: Tuesday, April 7, 2009, 7:43 AM
Leroy,
Gene Sharp
93' WL 40'
Ohio
> Steer Axel-
> BB 1286814
> Firestone-W01- 358-9457
> Goodyear 1R11-151
> Ridewell-1003589457 C
> Leroy Eckert
> Dahlonega, GA
> From: Gene Sharp
> To: WanderlodgeForum@ yahoogroups. com
> Hi,
> Air Springs
> 1286814 front
> 0961250 rear
> 0990671 tag
> Radaitor
> G & O #x-3190-11996
> Gene Sharp
> 93' WL 40'
> Belle Center, Ohio
04-07-2009, 00:48
Here is a Firestone number for the Tag-W013589073.
When it quits snowing I will go out to the bus and looks at my spares and see who made them and their part numbers.
Leroy Eckert
Dahlonega, GA
Royale Conversion
--- On Tue, 4/7/09, Leroy Eckert wrote:
Subject: Re: [WanderlodgeForum] Re: Air Bags (Springs) & Radiator order numbers
Date: Tuesday, April 7, 2009, 8:12 AM
Ridewell-100- 358-9073C
Drive-BB number-0961250- 4each
Ridewell-100- 358-9039C
http://www.ridewellcorp. com- Look under air spring part, by part number.
I show the same
Leroy Eckert
Dahlonega,
GA
Leroy,
Gene Sharp
93' WL 40'
Ohio
> Steer Axel-
> BB 1286814
> Goodyear 1R11-151
> Leroy Eckert
> Dahlonega, GA
> From: Gene Sharp
> Hi,
> Air Springs
> 1286814 front
> 0961250 rear
> 0990671 tag
> Radaitor
> G & O #x-3190-11996
> Gene Sharp
> 93' WL 40'
> Belle Center, Ohio
04-08-2009, 00:28
Hi Again,
Forgot to ask for a good place to purchase the air bags (springs). No more
questions.
My mind only works on one thing at a time.
Thanks,
Gene Sharp
93' WL 40' Ohio
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: Leroy Eckert
numbers
expensive.
> Leroy Eckert
> Dahlonega,
> GA
> From: Gene Sharp
numbers
> Leroy,
> Gene Sharp
> 93' WL 40'
> Ohio
> > Steer Axel-
> > BB 1286814
> > Goodyear 1R11-151
> > Leroy Eckert
> > Dahlonega, GA
> > From: Gene Sharp
> > Hi,
> > Air Springs
> > 1286814 front
> > 0961250 rear
> > 0990671 tag
> > Radaitor
> > G & O #x-3190-11996
> > Gene Sharp
> > 93' WL 40'
> > Belle Center, Ohio
04-08-2009, 00:41
Try your local fleet maintenance yard. Or if you can order on line.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Date: Wednesday, April 8, 2009, 8:28 AM
Hi Again,
Forgot to ask for a good place to purchase the air bags (springs). No more questions.
Thanks,
Gene Sharp
93' WL 40' Ohio
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: Leroy Eckert
> Leroy Eckert
> Dahlonega,
> GA
> From: Gene Sharp
> Leroy,
> Gene Sharp
> 93' WL 40'
> Ohio
> > Steer Axel-
> > BB 1286814
> > Goodyear 1R11-151
> > Leroy Eckert
> > Dahlonega, GA
> > From: Gene Sharp
> > Hi,
> > Air Springs
> > 1286814 front
> > 0961250 rear
> > 0990671 tag
> > Radaitor
> > G & O #x-3190-11996
> > Gene Sharp
> > 93' WL 40'
> > Belle Center, Ohio
04-08-2009, 01:05
Thank You - Thank You for your help !
Gene Sharp
93' WL 40' Oh
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> From: Gene Sharp
numbers
> Hi Again,
questions.
> Thanks,
> Gene Sharp
> 93' WL 40' Ohio
> > Leroy Eckert
> > Dahlonega, GA
> > Royale Conversion
> > From: Leroy Eckert
numbers
expensive.
> > Leroy Eckert
> > Dahlonega,
> > GA
> > From: Gene Sharp
numbers
> > Leroy,
> > Gene Sharp
> > 93' WL 40'
> > Ohio
> > > Steer Axel-
> > > BB 1286814
> > > Goodyear 1R11-151
> > > Leroy Eckert
> > > Dahlonega, GA
> > > From: Gene Sharp
numbers
> > > Hi,
> > > Air Springs
> > > 1286814 front
> > > 0961250 rear
> > > 0990671 tag
> > > Radaitor
> > > G & O #x-3190-11996
> > > Gene Sharp
> > > 93' WL 40'
> > > Belle Center, Ohio
04-08-2009, 10:15
You can search online. I let the guy who replaced them order them. A word of caution that bus is big and heavy. While they were repairingy bags the bus came down on the guy who was working on it he was not to badly hurt. We have had members killed under a wanderlodge !!
Thanks
Jim Riordan
On Apr 8, 2009, at 8:28, "Gene Sharp" <"jks_les@yahoo.com"> wrote:
Hi Again,
Thanks,
Gene Sharp
93' WL 40' Ohio
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> --- On Tue, 4/7/09, Leroy Eckert ...> wrote:
> From: Leroy Eckert ...>
> Leroy Eckert
> Dahlonega,
> GA
> From: Gene Sharp
> Leroy,
> Gene Sharp
> 93' WL 40'
> Ohio
> > Steer Axel-
> > BB 1286814
> > Goodyear 1R11-151
> > Leroy Eckert
> > Dahlonega, GA
> > From: Gene Sharp
> > Hi,
> > Air Springs
> > 1286814 front
> > 0961250 rear
> > 0990671 tag
> > Radaitor
> > G & O #x-3190-11996
> > Gene Sharp
> > 93' WL 40'
> > Belle Center, Ohio
ive,
div.file-title a:hover,
div.file-title a:visited {
text-decoration: none;
#ygrp-msg p {
clear: both;
padding: 15px 0 3px 0;
overflow: hidden;
#ygrp-msg p span {
color: #1E66AE;
font-weight: bold;
div#ygrp-mlmsg #ygrp-msg p a span.yshortcuts {
font-family: Verdana;
font-size: 10px;
font-weight: normal;
#ygrp-msg p a {
font-size: 10px;
#ygrp-mlmsg a {
color: #1E66AE;
div.attach-table div div a {
div.attach-table {
width: 400px;
