12 VOLT VOLTAGE DROP CHART
07-11-2009, 07:30
Hi
For those olf you concerned about voltage drop, use this handy link and learn about 10% and 3% critical voltage drop
Gary
http://www.marinco.com/page/wire-tech-data
--- On Thu, 7/9/09, David Josephson wrote:
Subject: [WanderlodgeForum] Re: 12v power for portable macerator pump
Date: Thursday, July 9, 2009, 4:35 PM
We have equipped a couple of coaches over the years with the Jabsco
macerator pump. It is very sensitive to voltage drop -- it really wants
at least 12 volts at the terminals, otherwise it stalls very easily. We
also strictly limit TP usage when we're going to use it (single ply
only, and try not to wad it up tightly when you toss). Running 10 gauge
wire from the batteries versus 14 gauge through a nearby circuit made
the difference in many cases between running or not. When first
installed, the coach or genset needed to be running (~14 volts at the
battery), now it works fine from a charged battery bank (12.3 - 12.8 V).
Cigarette lighter plugs are out -- too much resistance.
Now we are in the process of standardizing on a 12 volt outlet. The
solar house people use NEMA 6-15 plugs and outlets for 12V, we might use
those or 6-20. These look like regular 120 volt plugs but at least one
of the blades is sideways (intended for 240 volts).
David Josephson
Santa Cruz, CA
1983 Airstream diesel "Wanderlodge Lite"
--- In WanderlodgeForum@ yahoogroups. com, "Henry Jay Hannigan"
> Alex:
> When I put my DRAINMASTERS on (12volt dump valves), I just connected
into the 12volt overhead light wires....HOWEVER. ..your mixmaster may
require more operating current..... .....BOB LUMAS memmer of this Forum
has one and he knows the answer..
> Regrads,
> Hank
> 90SP36..for sale in Vegas
> --- In WanderlodgeForum@ yahoogroups. com, "Alex Smith" replytoalex@
> > Hello to all,
> > I would like to use a portable macerator pump from time to time. Any
help on the best way and from where to tap 12v 20 amp power would be
greatly appreciated! Thanks.
