Gauge lights will not come on
11-08-2009, 10:01
Does anyone know if there is a fuse for the gauge lights. The blue trim light
also does not come on. I was going to just run 12 volt positive wire and attach
it to one of the gauge light wires. Any help will be appreciated.
This is on a 1994 40ft.
Thanks
Nelson
11-08-2009, 11:42
Nelson
First thought is the dash dimmer switch was turned down.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
11-08-2009, 12:36
DO NOT attach 12 volt dc directly to the dash
the dash runs on weird cycle high voltage ac. The dc is inverted to this
by 4 inverters under the dash
check the grounds on the system then the rheostat controlling the dash
check for 12 volt dc going into the inverters (Small Blue Cubes marked high
voltage)
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote:
> Nelson
> Fred & Jeanne Hulse
> Morristown Arizona
11-09-2009, 02:28
Wanderlodge put in a large inverter in my 94pt in the genset rad bay. on the
forward wall, left . they look like a brick, white color
I found one died and I used the other one to run all the lights. the rheostats
control the 12 v into the brick inverters
test that the rheostat control has 12V to the input and then test that it is a
voltage sliding scale on the output as wou rotatte the knob. then I would test
that the voltage output is getting to the inverter then test the ac output of
the inverter.
I tested my el light by lighting them up with ac electric from a pepboys
inverter.
Greg
94ptca
voltage)
> > Nelson
> > Fred & Jeanne Hulse
> > Morristown Arizona
11-09-2009, 11:25
Thanks for all the help. I will check tomorrow on the inverter. I did make sure both rheostats were all the way clockwise. I will look for the inverters tomorrow. I did find one wire loose wire. It was a black shielded cable hanging near the rheostats but did not see any place where it would of attached to. I think the other end goes somewhere towards the front of the bus. I will have to take the front off tomorrow and try to find it. It's strange that both the dash & gauge lights went off at the same time.
Thanks for the help.
I will let you know what I find tomorrow.
Nelson SLinkman
--- On Mon, 11/9/09, gregory O wrote:
Subject: [WanderlodgeForum] Re: Gauge lights will not come on
Date: Monday, November 9, 2009, 9:28 AM
Wanderlodge put in a large inverter in my 94pt in the genset rad bay. on the forward wall, left . they look like a brick, white color
I found one died and I used the other one to run all the lights. the rheostats control the 12 v into the brick inverters
test that the rheostat control has 12V to the input and then test that it is a voltage sliding scale on the output as wou rotatte the knob. then I would test that the voltage output is getting to the inverter then test the ac output of the inverter.
I tested my el light by lighting them up with ac electric from a pepboys inverter.
Greg
94ptca
dash
> check for 12 volt dc going into the inverters (Small Blue Cubes marked high voltage)
> --- In WanderlodgeForum@ yahoogroups. com, "Fred Hulse" wrote:
> > Nelson
> > Fred & Jeanne Hulse
> > Morristown Arizona
11-09-2009, 11:26
bad ground if they both went off at the same time
Stephen
97BMC37
--- In WanderlodgeForum@yahoogroups.com, nelson slinkman wrote:
> Â
> Nelson SLinkman
> From: gregory O
> Â
the inverter.
inverter.
> Greg
> 94ptca
voltage)
> > > Nelson
> > > Fred & Jeanne Hulse
> > > Morristown Arizona
11-09-2009, 11:31
Thanks, Do you where I should check for ground?? I had put the ground lead of my meter on the tach frame and the + meter lead on the light switch and did get 12 volts. By the way is this brick inverter under the dash?
Thanks
Nelson
Date: Monday, November 9, 2009, 6:26 PM
Stephen
97BMC37
--- In WanderlodgeForum@ yahoogroups. com, nelson slinkman wrote:
> Â
tomorrow.
> Nelson SLinkman
> From: gregory O
> To: WanderlodgeForum@ yahoogroups. com
> Â
> Greg
> 94ptca
> > > Nelson
> > > First
> > > Fred & Jeanne Hulse
> > > Morristown Arizona
11-15-2009, 02:54
Yup
There is a fuse for gauge lights. You may also have a bad rheostat on the headlamp switch, or bad headlamp switch. If that's not enough, you could also have a bad ground on the string of gauges that don't work.
Gary
86pt40
--- On Sun, 11/8/09, nelsons wrote:
Subject: [WanderlodgeForum] Gauge lights will not come on
Date: Sunday, November 8, 2009, 5:01 PM
Does anyone know if there is a fuse for the gauge lights. The blue trim light also does not come on. I was going to just run 12 volt positive wire and attach it to one of the gauge light wires. Any help will be appreciated.
Thanks
Nelson
