Pulsation from small convereter
12-21-2012, 05:55
Ralph, I had a small (2 plug) converter (DC to AC) hook up to run my CPAP machine. I got the idea from you a few years back. I only use the device when I am not hooked up to AC power
The problem I have is that the CPAP pulsates when running on the converter. And I have replaced 1 CPAP after 4 days boondocking. As you can imagine if your breathing is not at the same speed as the pulse ...you wake up. The converter is hook up directly to the engine batteries in the bay. What do you think, a bad converter? Scooter 2000 XL Ocqueoc, MI |
12-21-2012, 07:15
It is possible to be a bad converter, or perhaps a bad connection to the 12 vdc source wiring or plug. We have been running Charolette's CPAP on our 275 watt inverter for some years now with out any problems. Check the connections for corrosion. I know when I am running the small inverter to power my lap top for GPS down the road I have to plug into the dash 12 vdc lighter socket rather than the one on the toe board near the co pilots seat because it will pulse. I have yet to trace the wiring. You might try an extension cord with the inverter at a different voltage source first. This should tell you if it is the inverter or the plug you now use. Ralph At 11:55 AM 12/21/2012 -0600, you wrote: >Ralph, I had a small (2 plug) converter (DC to AC) hook up to run my CPAP >machine. I got the idea from you a few years back. I only use the device >when I am not hooked up to AC power > The problem I have is that the CPAP pulsates when running on the > converter. And I have replaced 1 CPAP after 4 days boondocking. > >As you can imagine if your breathing is not at the same speed as the pulse >...you wake up. The converter is hook up directly to the engine batteries >in the bay. What do you think, a bad converter? > >Scooter >2000 XL Ocqueoc, MI > > > Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma 2005 Jeep Wrangler X _______ /l ,[____], l---L -OlllllllO- ()_) ()_)--o-)_) |
