Ride Height/Air Bag Measurement
06-04-2015, 11:23
(This post was last modified: 06-04-2015 11:28 by jwm470.)
[attachment=1731][attachment=1732][attachment=1733]Might be my imagination, but height seems to have changed. Do the pics of the air bags look normal?
89 Beaver Contessa (Sold) 96 Vogue Prima Vista (Sold) 97 Roadtrek 190 (Sold) 95 S-60 WB42 (Finally) |
06-05-2015, 13:55
RE: Ride Height/Air Bag Measurement
The tag looks overinflated. You probably know this but the air spring height should be measured from the bottom of the piston to the top of the bead plate as shown here:
Specs for the non-tag-steer LXi are: steer and drive: 8" +- 3/16" tag: 12.72" When things get out of kilter on an LXi it's usually a height control valve (HCV) or a panhard rod bushing (transverse link). Those spec's are from Ridewell. On my LXi my tag was always a bit higher than Ridewell's specs. If I recall, my tag air spring height measure around 14". I think BlueBird set the suspension up slightly differently from Ridewell's specs. BlueBird like the front to be raked down slightly which would add some height to the tag air springs. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
06-19-2015, 21:27
Blue Bird told me 9" plate to plate. May be different for a 99 but I think it may be more with whom you talked.
Charlie Vaughn 1999 LXi |
06-20-2015, 11:07
While on the subject of ride height, my 94 travels at a slight nose down attitude. Doesn't seem to bother anything, rides and handles well. Ive noticed other 94's seem to exhibit the same attitude. Why is it configured this way?
Tommy Rountree, AKA RetDA Still a Newbie 1994 WB |
06-20-2015, 20:37
Mine is that way also, Tommy, maybe they(the BB engineers) figured less worry about the rear of the coach dragging on steep driveways.
06-20-2015, 21:46
(This post was last modified: 06-20-2015 21:46 by davidbrady.)
Hi Tommy,
Bennie Collier told me (back in the day) that BB likes to have the coaches raked down in the front by three quarters of an inch or so. I guess they found over the years that the coaches handled and road better this way. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
06-28-2015, 08:27
on a recent air bag measure and adjust repair the tech was not able to get all bags to measure equal. Does any GuRu have any thoughts on what might be going on ?
all rear bags 8+- 3/16 front not the case . No mater what they did they could not get them all to measure up al perna 2000 LXI ormond beach fla |
