fan clutch over-ride switch
08-03-2005, 06:24
Hi Troy,
That switch is really handy and easy to install. Tom Warner and Bob Loomas (and I) put mine in, in about 20 minutes. I have a diagram I can send you that shows you how to connect it. While we were right there, we re-wired the wires going to the fan clutch, because these can get frayed and cause shorts, causing the fan clutch to operate erratically. Good luck, Tom Meservey, USN (Ret) '81FC33' WKRP [Non-text portions of this message have been removed] |
