					Unruly Generator!
					08-09-2005, 16:33
				Unruly Generator!
					Hello to all,
			On a recent outing with some fellow RVers we traveled to campground during a heavy rainstorm. I arrived at the campground with no problem that I could tell. Did all the things that we do when planning on staying a couple of days. We enjoyed the evening with other BB owners that were there. At about midnight I went to the bus for a nap. At about 2AM I felt something shake the bus and then I hear this awful noise of a diesel engine starting up. I think to myself, why would someone start a noisy engine at this hour of the night. I get up to see who has done such a thing and find out that it is my generator that is running. I run to the front to push the stop button. The engine stops running but the starter begins cranking trying to restart it. The engine will not restart but the starter just continues to try. I go outside and remove the cables from the gen start battery. This has no effect, so I go back and remove the cables from the house batterys. Still the starter is trying to restart the engine. Finally I go around and throw the circut breaker off on the AC power. All is silent now so I go back to bed. The next morning I try turning the AC back on but the starter begins cranking again. My friend and I finally managed to get the generator to run out and removed the leads to the starter to disable it. A couple of days later I put everything back and all is well. I have looked the control circut over and can see no problems. I have two questions, what could have caused this to happen and is it normal for the house batterys to crank the engine after the generator battery has been disconnected. I did wire a relay in the control circut power lead so if this happens again I can disable the crank and run circut with a toggle switch. Thanks, Johnny M Slone Pikeville, KY 84 PT34  |
					08-09-2005, 21:12
				Unruly Generator!
					Hi Johnny,
			Sounds to me like you could have a broken spring in your genset's starter solenoid (smaller cylinder mounted on top of the starter housing) If this spring breaks, the bendix arm can randomly close and initiate a start sequence. Either that, or one of your genny start switches sticks in the start position and someone bumped it when you were parked. What happened is very unusual, but after 20+ years... who knows. There are three ways to get power to the starter on the genset. If you disconnect both sets of batteries, voltage will still flow to the starter from the 12V inverter that charges your batteries while parked and gives your flourescent lights power. I would check the switches on the dinette panel and dash to see if they are sticking first. Removing amd checking the starter solenoid is a little more involved- just be sure to assign numbers to the studs, label all wires and disconnect all power first. Getting a new starter is pretty easy if you have a farm equpiment dealer nearby. Many of the small bobcat loaders have similar Delco starters. If you have one of the gold Kohler gensets, let me know the part # off the old starter. I just replaced mine with a rebuilt unit from Columbus, OH for about $140. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Johnny M Slone" > Hello to all, > On a recent outing with some fellow RVers we traveled to campground > during a heavy rainstorm. I arrived at the campground with no problem > that I could tell. Did all the things that we do when planning on > staying a couple of days. We enjoyed the evening with other BB owners > that were there. At about midnight I went to the bus for a nap. At > about 2AM I felt something shake the bus and then I hear this awful > noise of a diesel engine starting up. I think to myself, why would > someone start a noisy engine at this hour of the night. I get up to > see who has done such a thing and find out that it is my generator > that is running. I run to the front to push the stop button. The > engine stops running but the starter begins cranking trying to > restart it. The engine will not restart but the starter just > continues to try. I go outside and remove the cables from the gen > start battery. This has no effect, so I go back and remove the cables > from the house batterys. Still the starter is trying to restart the > engine. Finally I go around and throw the circut breaker off on the > AC power. All is silent now so I go back to bed. > > The next morning I try turning the AC back on but the starter begins > cranking again. My friend and I finally managed to get the generator > to run out and removed the leads to the starter to disable it. A > couple of days later I put everything back and all is well. I have > looked the control circut over and can see no problems. > > I have two questions, what could have caused this to happen and is it > normal for the house batterys to crank the engine after the generator > battery has been disconnected. > > I did wire a relay in the control circut power lead so if this > happens again I can disable the crank and run circut with a toggle > switch. > > Thanks, > Johnny M Slone > Pikeville, KY > 84 PT34  |
					08-10-2005, 05:11
				Unruly Generator!
					Johnny:
			The contacts in the starting solenoid are welding together so it sounds like. The 12vdc "C" relay must close to supply power to the "S" ( starter solenoid coil) for the starter to turn, then opens up to stop the starter but when it opens the contacts in that relay the coil of the CR relay ( 110vac) holds the rest of the circuit until the stop relay, "CR2" is energized by the stop switch. So if the starter tries to start again after pushing the stop switch then the run/start contacts in the start solenoid must have welded shut. That it is working ok now further supports that theory as probably the welded contacts have finally un stuck. But you can bet they will weld again soon. If you have an battery isolator then the house batteries should not supply 12vdc to the gen set, unless it has been by passed of has faulted as well. Or some contacts in the charging system for the gen battery are welded as well. These are high amperage solenoids and take a pretty good hit each time they are brought on line. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 04:33 AM 8/10/2005 +0000, you wrote: >Hello to all, >On a recent outing with some fellow RVers we traveled to campground >during a heavy rainstorm. I arrived at the campground with no problem >that I could tell. Did all the things that we do when planning on >staying a couple of days. We enjoyed the evening with other BB owners >that were there. At about midnight I went to the bus for a nap. At >about 2AM I felt something shake the bus and then I hear this awful >noise of a diesel engine starting up. I think to myself, why would >someone start a noisy engine at this hour of the night. I get up to >see who has done such a thing and find out that it is my generator >that is running. I run to the front to push the stop button. The >engine stops running but the starter begins cranking trying to >restart it. The engine will not restart but the starter just >continues to try. I go outside and remove the cables from the gen >start battery. This has no effect, so I go back and remove the cables >from the house batterys. Still the starter is trying to restart the >engine. Finally I go around and throw the circut breaker off on the >AC power. All is silent now so I go back to bed. > >The next morning I try turning the AC back on but the starter begins >cranking again. My friend and I finally managed to get the generator >to run out and removed the leads to the starter to disable it. A >couple of days later I put everything back and all is well. I have >looked the control circut over and can see no problems. > >I have two questions, what could have caused this to happen and is it >normal for the house batterys to crank the engine after the generator >battery has been disconnected. > >I did wire a relay in the control circut power lead so if this >happens again I can disable the crank and run circut with a toggle >switch. > >Thanks, >Johnny M Slone >Pikeville, KY >84 PT34 > > > > >  |
					08-10-2005, 14:15
				Unruly Generator!
					Thanks Ralph and Shane for your replys.
			Do you think that water in wiring harness to the start/stop switches inside could have caused this problem. I know that touching the lead from the start switch inside with a test light will pull up the ( I believe C relay ) and cause the engine to start. This tells me that a high resistance ground would probably do the same thing. The engine not restarting supports your opinion that the problem is the starter solenoid but why did it start the first time. I have tested the solenoids in the boost circut and they appear to be OK. After thinking about the order that I disconnected the batteries if I had first done the start battery and then the charger the starter probably have stopped cranking and I could have left the house batteries connected. Tomorrow I am going to do just that and see if the gen engine will crank without pushing the boost switch. Would this be a good test for the isolator? Thanks again, Johnny M Slone Pikeville, KY 1984 PT35 --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > Johnny: > > The contacts in the starting solenoid are welding together so it sounds > like. The 12vdc "C" relay must close to supply power to the "S" ( starter > solenoid coil) for the starter to turn, then opens up to stop the starter > but when it opens the contacts in that relay the coil of the CR relay ( > 110vac) holds the rest of the circuit until the stop relay, "CR2" is > energized by the stop switch. So if the starter tries to start again after > pushing the stop switch then the run/start contacts in the start solenoid > must have welded shut. That it is working ok now further supports that > theory as probably the welded contacts have finally un stuck. But you can > bet they will weld again soon. > > If you have an battery isolator then the house batteries should not supply > 12vdc to the gen set, unless it has been by passed of has faulted as well. > Or some contacts in the charging system for the gen battery are welded as > well. These are high amperage solenoids and take a pretty good hit each > time they are brought on line. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 04:33 AM 8/10/2005 +0000, you wrote: > >Hello to all, > >On a recent outing with some fellow RVers we traveled to campground > >during a heavy rainstorm. I arrived at the campground with no problem > >that I could tell. Did all the things that we do when planning on > >staying a couple of days. We enjoyed the evening with other BB owners > >that were there. At about midnight I went to the bus for a nap. At > >about 2AM I felt something shake the bus and then I hear this awful > >noise of a diesel engine starting up. I think to myself, why would > >someone start a noisy engine at this hour of the night. I get up to > >see who has done such a thing and find out that it is my generator > >that is running. I run to the front to push the stop button. The > >engine stops running but the starter begins cranking trying to > >restart it. The engine will not restart but the starter just > >continues to try. I go outside and remove the cables from the gen > >start battery. This has no effect, so I go back and remove the cables > >from the house batterys. Still the starter is trying to restart the > >engine. Finally I go around and throw the circut breaker off on the > >AC power. All is silent now so I go back to bed. > > > >The next morning I try turning the AC back on but the starter begins > >cranking again. My friend and I finally managed to get the generator > >to run out and removed the leads to the starter to disable it. A > >couple of days later I put everything back and all is well. I have > >looked the control circut over and can see no problems. > > > >I have two questions, what could have caused this to happen and is it > >normal for the house batterys to crank the engine after the generator > >battery has been disconnected. > > > >I did wire a relay in the control circut power lead so if this > >happens again I can disable the crank and run circut with a toggle > >switch. > > > >Thanks, > >Johnny M Slone > >Pikeville, KY > >84 PT34 > > > > > > > > > >  |
					08-11-2005, 01:11
				Unruly Generator!
					Johnny:
			Question: Is the redi line still in your Coach? Is it, or the compartment still in the curb side rear under the louvered door next to the battery bank? In the lower rear is where either the isolator or two heavy duty solenoids are located. It is doubtful that water on the start/stop switch would do this, though not impossible. Check the wiring coming out of the control box to the gen set for abrasions, cuts or general disrepair, that may be the cause. And it very well could be that something inside the start solenoid slipped, or a weak spring holding the contacts just finally made it to the contacts. Hard to tell, not being there. It is always hard to troubleshoot something that is working now. Safe travels, Ralph ( Off to Texas to do a PDI today) Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 02:15 AM 8/11/2005 +0000, you wrote: >Thanks Ralph and Shane for your replys. >Do you think that water in wiring harness to the start/stop switches >inside could have caused this problem. I know that touching the lead >from the start switch inside with a test light will pull up the ( I >believe C relay ) and cause the engine to start. This tells me that a >high resistance ground would probably do the same thing. The engine >not restarting supports your opinion that the problem is the starter >solenoid but why did it start the first time. I have tested the >solenoids in the boost circut and they appear to be OK. >After thinking about the order that I disconnected the batteries if I >had first done the start battery and then the charger the starter >probably have stopped cranking and I could have left the house >batteries connected. Tomorrow I am going to do just that and see if >the gen engine will crank without pushing the boost switch. Would >this be a good test for the isolator? >Thanks again, >Johnny M Slone >Pikeville, KY >1984 PT35 > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > Johnny: > > > > The contacts in the starting solenoid are welding together so it >sounds > > like. The 12vdc "C" relay must close to supply power to the "S" ( >starter > > solenoid coil) for the starter to turn, then opens up to stop the >starter > > but when it opens the contacts in that relay the coil of the CR >relay ( > > 110vac) holds the rest of the circuit until the stop relay, "CR2" >is > > energized by the stop switch. So if the starter tries to start >again after > > pushing the stop switch then the run/start contacts in the start >solenoid > > must have welded shut. That it is working ok now further supports >that > > theory as probably the welded contacts have finally un stuck. But >you can > > bet they will weld again soon. > > > > If you have an battery isolator then the house batteries should not >supply > > 12vdc to the gen set, unless it has been by passed of has faulted >as well. > > Or some contacts in the charging system for the gen battery are >welded as > > well. These are high amperage solenoids and take a pretty good hit >each > > time they are brought on line. > > >  |
