New Batteries and Stupid New Owner Tricks
09-16-2005, 08:47
I had 6 Trojan T105's installed today, new cables, and a battery disconnect
switch for the genset battery, so I can isolate it while dry camping. We ground the accumulated gunk off the battery tray and repainted it too. While the work was being done on the tray, I was troubleshooting the refer. I have never been able to get it to run on propane. I figured I'd purge the gas lines again by turning on the stove. I couldn't get it lit though. In fact I couldn't even smell the propane coming out of the burners. I started checking the knobs, checking for switches, opening cabinets and drawers looking for a hidden on/off valve etc. Finally I stumbled on the propane detector, when I turned it on, lo and behold, i had propane to the stove, and the refer lit right up :-) Damn these Bluebirds are complex!! Steve Harrie '86 PT38 Used to a Simple '03 Dutch Star [Non-text portions of this message have been removed] |
09-16-2005, 14:10
Steve:
If it makes any difference, we ALL have looked for that same switch at one time or other. And what's more on some Birds there is an additional switch on the drivers console that has to be on as well. sure, you won't forget where it is from now on! it is not a challenge but a true adventure. Ralph At 08:47 PM 9/16/2005 -0400, you wrote: >I had 6 Trojan T105's installed today, new cables, and a battery disconnect >switch for the genset battery, so I can isolate it while dry camping. We >ground >the accumulated gunk off the battery tray and repainted it too. > >While the work was being done on the tray, I was troubleshooting the refer. I >have never been able to get it to run on propane. I figured I'd purge the >gas lines again by turning on the stove. I couldn't get it lit though. In >fact I >couldn't even smell the propane coming out of the burners. > >I started checking the knobs, checking for switches, opening cabinets and >drawers looking for a hidden on/off valve etc. Finally I stumbled on the >propane >detector, when I turned it on, lo and behold, i had propane to the stove, and >the refer lit right up :-) > >Damn these Bluebirds are complex!! > >Steve Harrie >'86 PT38 >Used to a Simple '03 Dutch Star > > >[Non-text portions of this message have been removed] > > > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm |
