SKYLIGHT ADVICE
09-23-2005, 10:26
SKYLIGHT ADVICE
I was going to seal around my skylight today, turned into a much
bigger job than anticipated. I found that the rubber around the glass needs to be replaced and that there were years of sealant built up. I removed the skylight from the coach so that I can clean off the old stuff and start fresh. Any advice on this job and does anyone know if I can still get a new rubber gasket for the glass? Thanks! Robert Britton 87FC Tres Pinos Ca. |
