refrigerator problems
10-12-2005, 01:25
Post: #31
We were not so lucky, went around a sharp turn in the road and the
door opened and half the stuff fell on the floor. What a mess, broken glass and liquids on the floor, and no place to pull over and stop. We were almost at our campground and I was mopping the floor while we waited for the gate guard to get there and let us in. We went to a nearby RV dealer and bought Thumb Locks for the doors. They seem to work well, we have only moved twice since we put them on the refrigerator doors but they were some curvy two lane roads and the tight circular ramps to and from freeways. Julie Bonser 1992 WLWB PT 40' Madison, Wi for Dr. appointments good news so far. On Oct 12, 2005, at 7:11 AM, erniecarpet@... wrote: > So far have been lucky. Might have to put a bungee cord on it if I > buy a > bunch of groceries. Ernie- 83pt40 in montana > > |
10-13-2005, 06:41
Post: #32
Howdy, George.
<<<--- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: We have never had a problem while traveling or when parked, though we do have a large battery bank which would be required in ANY all electric coach.>>> How many batteries are in this bank? I am intrigued by the idea of having a house-type frig. How many inverters do you have? Thanks, Liz Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL |
05-25-2009, 04:25
Post: #33
I'm currently on the road and my refrigerator is doing some goofy stuff. I
believe it's a replacement to my 85 PT40. It's a Dometic 3807 Royal Designer Series. I don't have the manual for the frig (wasn't in the Blue Box) and I've researched a little online. Here's what it is doing: - It seems to run fine on AC setting then suddenly switches to DC. While on AC, the number 1 setting (1 - 5) seems to stay plenty cool. - When it switches to DC (without prompting while still hooked to shore power) it tends to warm up even in the 5 setting. - All breakers seem to be fine and there is power at the outlet (when tested) at the back of the frig. - There doesn't seem to be any rhyme or reason on when/why it switches from AC to DC. Any thoughts? It might be that I am ready for a new frig (don't really think so) or ready for a rebuild. Or, the circuit board may need replaced. Hope you all have a great Memorial Day and thanks for your service to our country! Jerry 85 PT40 |
05-25-2009, 04:37
Post: #34
On 5/25/09, <b class="gmail_sendername">jburgessx2[/b] <"jburgessx2@yahoo.com"> wrote:
I'm currently on the road and my refrigerator is doing some goofy stuff.  I believe it's a replacement to my 85 PT40.  It's a Dometic 3807 Royal Designer Series.  I don't have the manual for the frig (wasn't in the Blue Box) and I've researched a little online.  Here's what it is doing: when the OEM can't get the job done.
Â
Â
 Steve
 Wannabee
Â
05-25-2009, 17:09
Post: #35
Jerry You may want to do a forum search here
http://www.rvmobile.com/ they are a good source for Einsteins troubleshooting Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "jburgessx2" > > I'm currently on the road and my refrigerator is doing some goofy stuff. I believe it's a replacement to my 85 PT40. It's a Dometic 3807 Royal Designer Series. I don't have the manual for the frig (wasn't in the Blue Box) and I've researched a little online. Here's what it is doing: > > - It seems to run fine on AC setting then suddenly switches to DC. While on AC, the number 1 setting (1 - 5) seems to stay plenty cool. > > - When it switches to DC (without prompting while still hooked to shore power) it tends to warm up even in the 5 setting. > > - All breakers seem to be fine and there is power at the outlet (when tested) at the back of the frig. > > - There doesn't seem to be any rhyme or reason on when/why it switches from AC to DC. > > Any thoughts? It might be that I am ready for a new frig (don't really think so) or ready for a rebuild. Or, the circuit board may need replaced. > > Hope you all have a great Memorial Day and thanks for your service to our country! > > Jerry 85 PT40 > |
05-26-2009, 02:26
Post: #36
Hi Jerry:
Replace the circuit board with a dinosaur board. The board senses the changes in voltage and goes to what is sensed or default if not. 1. 110vac is first, 2. LP then 12 vdc if the other 2 are not sensed. Point is, the board is telling your system what to do. While you in there, do an ohms check on the 12vdc heater, it may be open and not working. At best the vdc setting is poor. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 04:25 PM 5/25/2009 +0000, you wrote: >I'm currently on the road and my refrigerator is doing some goofy >stuff. I believe it's a replacement to my 85 PT40. It's a Dometic 3807 >Royal Designer Series. I don't have the manual for the frig (wasn't in >the Blue Box) and I've researched a little online. Here's what it is doing: > > - It seems to run fine on AC setting then suddenly switches to > DC. While on AC, the number 1 setting (1 - 5) seems to stay plenty cool. > > - When it switches to DC (without prompting while still hooked to shore > power) it tends to warm up even in the 5 setting. > > - All breakers seem to be fine and there is power at the outlet (when > tested) at the back of the frig. > > - There doesn't seem to be any rhyme or reason on when/why it switches > from AC to DC. > >Any thoughts? It might be that I am ready for a new frig (don't really >think so) or ready for a rebuild. Or, the circuit board may need replaced. > >Hope you all have a great Memorial Day and thanks for your service to our >country! > >Jerry 85 PT40 > > |
05-26-2009, 02:33
Post: #37
Thanks to all who responded. I may need to replace the board.
What's odd is that during the day it will switch to DC. At night it automatically switches back to AC and stays on AC all through the night and into the morning. I'm wondering if it has something to do with the heat of the day? Why does it switch to AC at night only??? It's another one of those little oddities that keeps life interesting. Jerry 85 PT40 --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" wrote: > > Hi Jerry: > > Replace the circuit board with a dinosaur board. The board senses the > changes in voltage and goes to what is sensed or default if not. 1. 110vac > is first, 2. LP then 12 vdc if the other 2 are not sensed. Point is, the > board is telling your system what to do. While you in there, do an ohms > check on the 12vdc heater, it may be open and not working. At best the vdc > setting is poor. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 "Ruff Diamond" > Duncan, Oklahoma > > At 04:25 PM 5/25/2009 +0000, you wrote: > >I'm currently on the road and my refrigerator is doing some goofy > >stuff. I believe it's a replacement to my 85 PT40. It's a Dometic 3807 > >Royal Designer Series. I don't have the manual for the frig (wasn't in > >the Blue Box) and I've researched a little online. Here's what it is doing: > > > > - It seems to run fine on AC setting then suddenly switches to > > DC. While on AC, the number 1 setting (1 - 5) seems to stay plenty cool. > > > > - When it switches to DC (without prompting while still hooked to shore > > power) it tends to warm up even in the 5 setting. > > > > - All breakers seem to be fine and there is power at the outlet (when > > tested) at the back of the frig. > > > > - There doesn't seem to be any rhyme or reason on when/why it switches > > from AC to DC. > > > >Any thoughts? It might be that I am ready for a new frig (don't really > >think so) or ready for a rebuild. Or, the circuit board may need replaced. > > > >Hope you all have a great Memorial Day and thanks for your service to our > >country! > > > >Jerry 85 PT40 > > > > > |
05-26-2009, 02:44
Post: #38
Not really odd in some ways. Electronics have always had the reputation of
failing do to heat. Though todays electronics are less sensitive some "parts" can be and fail. You more than likely have a Dometic board installed and they are "potted" other wise I would suggest waiting until night the take the wifes hair drier out there and apply heat and see if it changes. You have a relay on that board that is heat sensitive or a triac that is heat sensitive. I remember when nixi tubes would heat up the "fire" spurious things would really happen then,, oops nixi tubes, am I dating my self or what? LOL Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 02:33 PM 5/26/2009 +0000, you wrote: >Thanks to all who responded. I may need to replace the board. > >What's odd is that during the day it will switch to DC. At night it >automatically switches back to AC and stays on AC all through the night >and into the morning. I'm wondering if it has something to do with the >heat of the day? Why does it switch to AC at night only??? > >It's another one of those little oddities that keeps life interesting. > >Jerry >85 PT40 > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Hi Jerry: > > > > Replace the circuit board with a dinosaur board. The board senses the > > changes in voltage and goes to what is sensed or default if not. 1. 110vac > > is first, 2. LP then 12 vdc if the other 2 are not sensed. Point is, the > > board is telling your system what to do. While you in there, do an ohms > > check on the 12vdc heater, it may be open and not working. At best the vdc > > setting is poor. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 "Ruff Diamond" > > Duncan, Oklahoma > > > > At 04:25 PM 5/25/2009 +0000, you wrote: > > >I'm currently on the road and my refrigerator is doing some goofy > > >stuff. I believe it's a replacement to my 85 PT40. It's a Dometic 3807 > > >Royal Designer Series. I don't have the manual for the frig (wasn't in > > >the Blue Box) and I've researched a little online. Here's what it is > doing: > > > > > > - It seems to run fine on AC setting then suddenly switches to > > > DC. While on AC, the number 1 setting (1 - 5) seems to stay plenty cool. > > > > > > - When it switches to DC (without prompting while still hooked to shore > > > power) it tends to warm up even in the 5 setting. > > > > > > - All breakers seem to be fine and there is power at the outlet (when > > > tested) at the back of the frig. > > > > > > - There doesn't seem to be any rhyme or reason on when/why it switches > > > from AC to DC. > > > > > >Any thoughts? It might be that I am ready for a new frig (don't really > > >think so) or ready for a rebuild. Or, the circuit board may need > replaced. > > > > > >Hope you all have a great Memorial Day and thanks for your service to our > > >country! > > > > > >Jerry 85 PT40 > > > > > > > > > |
05-26-2009, 02:56
Post: #39
Thanks Greg - it looks like a good forum to ask questions as well. I did a
search to no avail so I decided to post the problem there. So, I should be getting an answer soon. Jerry 85 PT40 --- In WanderlodgeForum@yahoogroups.com, "timvasqz" > > Jerry You may want to do a forum search here > http://www.rvmobile.com/ > they are a good source for Einsteins troubleshooting > Greg of Tim&Greg 94ptca > --- In WanderlodgeForum@yahoogroups.com, "jburgessx2" > > > > I'm currently on the road and my refrigerator is doing some goofy stuff. I believe it's a replacement to my 85 PT40. It's a Dometic 3807 Royal Designer Series. I don't have the manual for the frig (wasn't in the Blue Box) and I've researched a little online. Here's what it is doing: > > > > - It seems to run fine on AC setting then suddenly switches to DC. While on AC, the number 1 setting (1 - 5) seems to stay plenty cool. > > > > - When it switches to DC (without prompting while still hooked to shore power) it tends to warm up even in the 5 setting. > > > > - All breakers seem to be fine and there is power at the outlet (when tested) at the back of the frig. > > > > - There doesn't seem to be any rhyme or reason on when/why it switches from AC to DC. > > > > Any thoughts? It might be that I am ready for a new frig (don't really think so) or ready for a rebuild. Or, the circuit board may need replaced. > > > > Hope you all have a great Memorial Day and thanks for your service to our country! > > > > Jerry 85 PT40 > > > |
05-27-2009, 02:35
Post: #40
Ralph;
Nixie is old,,, I remember repairing HP test equipment, lots of Nixie tubes in the 60's Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" wrote: > > Not really odd in some ways. Electronics have always had the reputation of > failing do to heat. Though todays electronics are less sensitive some > "parts" can be and fail. You more than likely have a Dometic board > installed and they are "potted" other wise I would suggest waiting until > night the take the wifes hair drier out there and apply heat and see if it > changes. You have a relay on that board that is heat sensitive or a triac > that is heat sensitive. I remember when nixi tubes would heat up the "fire" > spurious things would really happen then,, oops nixi tubes, am I dating my > self or what? LOL > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 "Ruff Diamond" > Duncan, Oklahoma > > At 02:33 PM 5/26/2009 +0000, you wrote: > >Thanks to all who responded. I may need to replace the board. > > > >What's odd is that during the day it will switch to DC. At night it > >automatically switches back to AC and stays on AC all through the night > >and into the morning. I'm wondering if it has something to do with the > >heat of the day? Why does it switch to AC at night only??? > > > >It's another one of those little oddities that keeps life interesting. > > > >Jerry > >85 PT40 > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > Hi Jerry: > > > > > > Replace the circuit board with a dinosaur board. The board senses the > > > changes in voltage and goes to what is sensed or default if not. 1. 110vac > > > is first, 2. LP then 12 vdc if the other 2 are not sensed. Point is, the > > > board is telling your system what to do. While you in there, do an ohms > > > check on the 12vdc heater, it may be open and not working. At best the vdc > > > setting is poor. > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > 84FC35 "Ruff Diamond" > > > Duncan, Oklahoma > > > > > > At 04:25 PM 5/25/2009 +0000, you wrote: > > > >I'm currently on the road and my refrigerator is doing some goofy > > > >stuff. I believe it's a replacement to my 85 PT40. It's a Dometic 3807 > > > >Royal Designer Series. I don't have the manual for the frig (wasn't in > > > >the Blue Box) and I've researched a little online. Here's what it is > > doing: > > > > > > > > - It seems to run fine on AC setting then suddenly switches to > > > > DC. While on AC, the number 1 setting (1 - 5) seems to stay plenty cool. > > > > > > > > - When it switches to DC (without prompting while still hooked to shore > > > > power) it tends to warm up even in the 5 setting. > > > > > > > > - All breakers seem to be fine and there is power at the outlet (when > > > > tested) at the back of the frig. > > > > > > > > - There doesn't seem to be any rhyme or reason on when/why it switches > > > > from AC to DC. > > > > > > > >Any thoughts? It might be that I am ready for a new frig (don't really > > > >think so) or ready for a rebuild. Or, the circuit board may need > > replaced. > > > > > > > >Hope you all have a great Memorial Day and thanks for your service to our > > > >country! > > > > > > > >Jerry 85 PT40 > > > > > > > > > > > > > > |
