Actuator for Swing Down Jack
11-20-2005, 19:51
Curt, Bim Burt and I changed the actuator on my coach. It was a pain as BOTH
those ports must aglign with the jack. The hydraulic fluid flows from those ports. I believe we used an oversize worm clamp and then tightened it so that the original clamp could be used. It is best if you swing your jack down and tie it so that it won't keep trying to kick up. Ernie- 83pt40 in texas [Non-text portions of this message have been removed] |
11-21-2005, 00:21
One front swing down leveling jack is leaking oil out the Actuator
bottom cap breather hole. This means the internal seals are leaking. HWH sent an Actuator. There are two little round things, about a dime or nickel in size, with o-rings, that fit between the jack and the actuator. They look to be a PITA to change without removing the jack. Has anyone changed an Actuator? Can it be done on the vehicle, or should the entire jack be removed? -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
11-21-2005, 01:16
No, Curt, not much. But a few shop towels would be a good idea. The actuators
ports can come off, so be careful- thats why they are taped. Ernie- who learned the hard way in texas [Non-text portions of this message have been removed] |
11-21-2005, 02:53
Will a lot of fluid flow out when the actuator is removed?
Curt Sprenger 1987 PT38, Anaheim Hills, Calif. erniecarpet@... wrote: > Curt, Bim Burt and I changed the actuator on my coach. It was a pain > as BOTH > those ports must aglign with the jack. The hydraulic fluid flows from > those > ports. I believe we used an oversize worm clamp and then tightened it > so that > the original clamp could be used. It is best if you swing your jack > down and tie > it so that it won't keep trying to kick up. Ernie- 83pt40 in texas > > > [Non-text portions of this message have been removed] > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
