Air Conditioner Questions
02-21-2006, 04:45
Howdy, Y'all.
We have a pair of Dometic Penguin roof air conditioners that are original equipment on our 1993 Wanderlodge.(The middle unit has been replaced). That means they are at least 12 years old. The bedroom air conditioner's fan is so noisy that Liz refuses to use it. The livingroom air conditioner's fan is getting slightly noisy, too. And Liz is starting to make unhappy noises about that!! [ ] [ ]There is 1/4 to 3/8 inch of play on the fan motor bearings/bushings. The compressors APPEAR to be OK. The question is what is the average life expectancy of the compressor? If it is 10 to 15 years, then I need to replace both air conditioners. If it is 20 years or more, then I need to replace JUST the fan motors, which is a LOT cheaper. Answers, comments and suggestions would be MOST welcome. Regards, Jack(now UNEMPLOYED) Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL [Non-text portions of this message have been removed] |
02-21-2006, 05:02
Jack,
My practice is to replace fan motors until the compressors start making noise. On my 91 I have only replaced one AC unit and we use them alot in Texas. On My 78FC31 I eventually replaced both units, but not until they were on their "last legs". I actually bought a Dometic 13000 btu at Camping Woreld on a Special at six-months-same-as-cash deal and stored it until the last one finally died! Bob & Judy Johannesen 91WLWB40 "Seldom Blue" Argyle, Texas Jack and Liz Pearce Howdy, Y'all. We have a pair of Dometic Penguin roof air conditioners that are original equipment on our 1993 Wanderlodge.(The middle unit has been replaced). That means they are at least 12 years old. The bedroom air conditioner's fan is so noisy that Liz refuses to use it. The livingroom air conditioner's fan is getting slightly noisy, too. And Liz is starting to make unhappy noises about that!! [ ] [ ]There is 1/4 to 3/8 inch of play on the fan motor bearings/bushings. The compressors APPEAR to be OK. The question is what is the average life expectancy of the compressor? If it is 10 to 15 years, then I need to replace both air conditioners. If it is 20 years or more, then I need to replace JUST the fan motors, which is a LOT cheaper. Answers, comments and suggestions would be MOST welcome. Regards, Jack(now UNEMPLOYED) Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- What are the most popular cars? Find out at Yahoo! Autos [Non-text portions of this message have been removed] |
02-21-2006, 05:06
I have replaced my 13.5 Dometic with 15.0 heat pumps. Cost was around
3500.oo for everything. Don't have exact price as will pick up end of the week. I replaced as units were 15 years old. I had noticed a low voltage light even when on generator. Felt it indicated potential problems and the idea of traveling to FL. with only two ac was not worth the risk. It is my hope that the heat pump will allow a diminished dependence on the PRIMUS... Just put new pumps on them and they work well but if I can use the campground power to heat my coach, I don't have to burn my propane. I was told to expect them to work well down to 35-40 degrees, after that we will need and electric or propane boost. My work was done at Foothills RV in Taylorsville NC. Bills out at 60/hr. Dont know how that compares but its cheaper that Camping World at 100/hr. john redden 91PT40 [Non-text portions of this message have been removed] |
