Generator fan
04-09-2006, 14:49
Generator fan
Hi Bob,
Since my gen set only has a fan with belts to crankshaft, no motor is attached...am I missing somethin here (besides finding my teeth?) ![]() Bob Lawrence 84 PT36 Tacoma, Wa > > > The person that owned my coach before me installed a 12 volt fan for the generator. > I had to change mine back to the 220 motor inorder to keep the gen set from shuting > down on over temp.If you can stay in a area that does not get over 70 dgrees and keep > the generator out of the sun it may work. > Bob Loomas 1985 PT 36 > > |
04-09-2006, 15:31
Generator fan
From: Bob Lawrence To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 09, 2006 9:49 PM Subject: [WanderlodgeForum] Generator fan You do have a differnt set up on the 84 then i do but i do have the same size radiator as you do and the 12 volt would not cool the radiator. I dont beleave you will get the CFM with a 12 volt electric fan for proper cooling under a 50% generator load. Let us know how it works for you. Bob Loomas 1985 PT 36 Hi Bob, Since my gen set only has a fan with belts to crankshaft, no motor is attached...am I missing somethin here (besides finding my teeth?) ![]() Bob Lawrence 84 PT36 Tacoma, Wa > > > The person that owned my coach before me installed a 12 volt fan for the generator. > I had to change mine back to the 220 motor inorder to keep the gen set from shuting > down on over temp.If you can stay in a area that does not get over 70 dgrees and keep > the generator out of the sun it may work. > Bob Loomas 1985 PT 36 > > -------------------------------------------------------------------------------- YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. -------------------------------------------------------------------------------- [Non-text portions of this message have been removed] |
04-10-2006, 12:02
Generator fan
You might be right, Bob, I will have to see the ratings of CFM
fans...maybe 2 fans side by side as seen on some cars? Bob Lawrence 84 PT36 (Being half deaf, gen set STILL to loud) Tacoma, Wa > You do have a differnt set up on the 84 then i do but i do have the same size radiator as you do > and the 12 volt would not cool the radiator. I dont beleave you will get the CFM > with a 12 volt electric fan for proper cooling under a 50% generator load. > Let us know how it works for you. > Bob Loomas 1985 PT 36 > > |
01-27-2007, 12:05
Generator fan
Hi I have a 1980fc33 with a12.5 kohler gen. A previous owner changed the
stock cooling fan with a plastic one which also reversed the direction of air flo. I am not happy with the cooling performance of this set up gen. will run up to 200 deg. with two A/C's on I have checked and tightened water pump belt on the perkins engine. I would like to find out the part number for the stock fan and hub assy. and where to purchase one. Thank you Mark |
