Dometic Fridge cycling
05-30-2006, 00:59
I just finished replacing the door gaskets on the fridge in my 90 S
P36 and noted that when I started the unit (on propane) that it would cycle off and then relight instantly about once every 5 minutes. All the air was bled out of the line and the igniter relit the flame on the first try each cycle. Is this normal and if not what needs replaced? Chuck Harrison 90 S P36 Akron, Ohio |
05-30-2006, 01:24
Chuch,
I would first clean out the burner box. There may be carbon, rust particles, spiders etc. Compressed air or a gentle brush. The thermocouple should be in the blue flame. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > I just finished replacing the door gaskets on the fridge in my 90 S > P36 and noted that when I started the unit (on propane) that it would > cycle off and then relight instantly about once every 5 minutes. All > the air was bled out of the line and the igniter relit the flame on > the first try each cycle. Is this normal and if not what needs > replaced? > > Chuck Harrison > 90 S P36 > Akron, Ohio > |
