water leak suggestions?
06-18-2006, 06:26
Post: #21
Kerry, give me a call and we can talk about what you are seeing.
Bruce Morris (919)872-7635 Raleigh, NC
Webmaster - Wanderlodge Owners Online
1983 WL FC35RB
FMCA: 7142s Ham Radio: KI4ME
Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv
Sent: Wednesday, June 14, 2006 7:53 AM
Subject: [WanderlodgeForum] Re: water leak suggestions?
I think I still must be missing something. I can only see three lines
coming from the tank/hw heater area going forward. One is from the
tank going to the pump under the sink. I had assumed the other two
were hot/cold that operated either on city pressure or were
pressurized from the pump somewhere under the sink. But if one is a
return pump pressure line then it seems another line is necessary for hot.
Kerry
--- In WanderlodgeForum@yahoogroups.com, "Stephen" <share@...> wrote:
> Through the regular hot water lines coming direct from the heater..
I guess
> I should have worded the last one more clearly..
> _____
> [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards
> Sent: Tuesday, June 13, 2006 7:13 PM
> How does the hot water get from the tank to the front?
> Kerry
> yahoogroups.com, "Stephen" <share@> wrote:
> > The pipes are as follows:
> > 1 is pressurized city water
> > 2 is fresh water from the tank
> > 3 is return from WP to pressurize Hot water tank
> > Stephen Hare
> > 81 FC-33SB
> > Plant City, Fl
06-19-2006, 08:46
Post: #22
Thanks. I'm on the road right now. I'll call when I get home in a
month or so. I've got the cold water working fine but I don't seem to
have hot water yet.
Kerry
82 FC 35
Denver
> 1983 WL FC35RB
> From: davidkerryedwards
for hot.
> Kerry
> I guess
> > _____
davidkerryedwards
> > Kerry
> > > Stephen Hare
> > > 81 FC-33SB
> > > Plant City, Fl
