Propane Pressure Regulator
07-11-2006, 14:35
Now I do have a propane problem after all. When I had my propane tank
filled last night, it was apparently overfilled and blew the pressure relieve valve on the tank's regulator (lost 3/4 of a tank). Does know where we can find these old style regulators or a substitute? Ron, No. California 85PT36 |
07-11-2006, 14:59
Marshall Brass makes a two stage unit #294-00. This is for the horizontal
mount, the vertical mount is # 290-00. Complement this new item with an CCI LP leak detector that shuts off the tank in case of a leak. Part #7770.7, use control solenoid # 7718. Both my birds have these controls and I sleep better knowing they are there. MH ----- Original Message ----- From: Ron & Patty To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 11, 2006 9:35 PM Subject: [WanderlodgeForum] Propane Pressure Regulator Now I do have a propane problem after all. When I had my propane tank filled last night, it was apparently overfilled and blew the pressure relieve valve on the tank's regulator (lost 3/4 of a tank). Does know where we can find these old style regulators or a substitute? Ron, No. California 85PT36 [Non-text portions of this message have been removed] |
07-11-2006, 15:26
The best I source I have found is Suburban Propane. One of the best
prices for propane, parts, installation. They have many outlets in California and other states. They are a volume propane distributor, but they take care of leaks, parts, upgrades, etc. All I needed to do was to call and make an appointment. They will also test your propane system, which is a good thing to do every few years. Try this to locate a store near you. http://www.suburbanpropane.com/consumer/...index.html Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Ron & Patty wrote: > Now I do have a propane problem after all. When I had my propane tank > filled last night, it was apparently overfilled and blew the pressure > relieve valve on the tank's regulator (lost 3/4 of a tank). Does know > where we can find these old style regulators or a substitute? > > Ron, No. California > 85PT36 > > |
07-11-2006, 16:02
Call me tomorrow after 9am PST I will give you the phone # of the
company in Fresno that had the High Pressure regulator I needed.I went to at least 6 places (propane dealers,R.V. service shops) around Sacramento with no luck. Jim Matus 916-635-8790 1984 FC35 Rescue CA >-- In WanderlodgeForum@yahoogroups.com, "Ron & Patty" wrote: > > Now I do have a propane problem after all. When I had my propane tank > filled last night, it was apparently overfilled and blew the pressure > relieve valve on the tank's regulator (lost 3/4 of a tank). Does know > where we can find these old style regulators or a substitute? > > Ron, No. California > 85PT36 > |
07-11-2006, 22:43
Hi Mike,
Good Rec- I replaced my old regulator with the Marshall Brass two- stage unit and also the CCI leak detector this past spring. Both work great. Marshall brass also has a "tee" connection that can be installed for gas grills just after the 2-stage regulator. This works great for connecting grills, etc.. to the main propane tank. I believe that it came with a 12' hose that will connect to anything that uses the small propane cannisters. You can also get an adapter for larger grills. It's certainly safer than lugging around loose canisters or a 20# propane tank. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Marshall Brass makes a two stage unit #294-00. This is for the horizontal mount, the vertical mount is # 290-00. Complement this new item with an CCI LP leak detector that shuts off the tank in case of a leak. Part #7770.7, use control solenoid # 7718. Both my birds have these controls and I sleep better knowing they are there. > MH > ----- Original Message ----- > From: Ron & Patty > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, July 11, 2006 9:35 PM > Subject: [WanderlodgeForum] Propane Pressure Regulator > > > Now I do have a propane problem after all. When I had my propane tank > filled last night, it was apparently overfilled and blew the pressure > relieve valve on the tank's regulator (lost 3/4 of a tank). Does know > where we can find these old style regulators or a substitute? > > Ron, No. California > 85PT36 > > > > > > [Non-text portions of this message have been removed] > |
07-13-2006, 04:04
Appreciate the quick responses from all.... I'll look into this unit
Mike, and thank you Jim for the Fresno connection. I'll give you a call when I get back. We're sitting at Lake Almanor in northern Calfornia right now. We're at North Shore Campgrounds. All the sites are large, and terraced amongst the pines, providing each with a view of the lake and Mt. Lassen. If you get near, be sure to stop at this place. http://www.northshorecampground.com/index.htm In the meantime, I got lucky and found a high pressure regulator at an RV dealer just several miles from our home. I will look into the Marshall Brass though. This one was cheap, and gets us down the road with cold beer for now, but doesn't have any safety features you mentioned Mike. Anyway, we're good for the moment. I really thought we'd be icebox'n it on this trip, which is too close to like real camping. This ole birds got us spoiled some. Thanks again, Ron No. California 85PT36 --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Marshall Brass makes a two stage unit #294-00. This is for the horizontal mount, the vertical mount is # 290-00. Complement this new item with an CCI LP leak detector that shuts off the tank in case of a leak. Part #7770.7, use control solenoid # 7718. Both my birds have these controls and I sleep better knowing they are there. > MH > ----- Original Message ----- > From: Ron & Patty > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, July 11, 2006 9:35 PM > Subject: [WanderlodgeForum] Propane Pressure Regulator > > > Now I do have a propane problem after all. When I had my propane tank > filled last night, it was apparently overfilled and blew the pressure > relieve valve on the tank's regulator (lost 3/4 of a tank). Does know > where we can find these old style regulators or a substitute? > > Ron, No. California > 85PT36 > > > > > > [Non-text portions of this message have been removed] > |
