Still, where are my circuit breakers..??
08-21-2006, 10:02
Ok, I remember now that those side lights are turn lights.
(Although preliminary tests say they still aren't working.) I'll go outside a little later when the temp drops below 105 and try again. However, I'm still confused on where some of my circuit breakers are. My manual shows the following Load Centers: 1. Lower Front Load Center (This is the one I can't seem to find.) 2. Overhead Front Load Center (This appears to be the one in the cabinet over the driver.) 3. Left Front Load Center (Over couch) 4. Right Front Load Center (Over chair) 5. Left Rear Load Center (I haven't looked for this one.) 6. Right Read Load Center (I haven't looked for this one.) Where is #1?? Thanks! Alan Johnson 87FC35 |
08-21-2006, 10:20
Alan,
I'm guessing as our coach is the '87PT model. The PT bay, below the driver seat, has lots of load center stuff anchored on the inside wall at the top of that bay. I can't see any of it unless I get down low and look up. Could BB have done the same with the FC??? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Alan wrote: > Ok, I remember now that those side lights are turn lights. > (Although preliminary tests say they still aren't working.) I'll go > outside a little later when the temp drops below 105 and try again. > > However, I'm still confused on where some of my circuit breakers > are. My manual shows the following Load Centers: > > 1. Lower Front Load Center (This is the one I can't seem to find.) > 2. Overhead Front Load Center (This appears to be the one in the > cabinet over the driver.) > 3. Left Front Load Center (Over couch) > 4. Right Front Load Center (Over chair) > 5. Left Rear Load Center (I haven't looked for this one.) > 6. Right Read Load Center (I haven't looked for this one.) > > Where is #1?? > > Thanks! > Alan Johnson > 87FC35 > > |
08-21-2006, 12:04
The FC models have three strips of circuit breakers on the drivers
side front panel. Two across the front and one behind the steering column. tom Warner Vernon Center,NY 1985 PT 40 At 06:20 PM 8/21/2006, you wrote: >Alan, >I'm guessing as our coach is the '87PT model. The PT bay, below the >driver seat, has lots of load center stuff anchored on the inside wall >at the top of that bay. I can't see any of it unless I get down low and >look up. Could BB have done the same with the FC??? > >Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > >Alan wrote: > > > Ok, I remember now that those side lights are turn lights. > > (Although preliminary tests say they still aren't working.) I'll go > > outside a little later when the temp drops below 105 and try again. > > > > However, I'm still confused on where some of my circuit breakers > > are. My manual shows the following Load Centers: > > > > 1. Lower Front Load Center (This is the one I can't seem to find.) > > 2. Overhead Front Load Center (This appears to be the one in the > > cabinet over the driver.) > > 3. Left Front Load Center (Over couch) > > 4. Right Front Load Center (Over chair) > > 5. Left Rear Load Center (I haven't looked for this one.) > > 6. Right Read Load Center (I haven't looked for this one.) > > > > Where is #1?? > > > > Thanks! > > Alan Johnson > > 87FC35 > > > > > > > > >Yahoo! Groups Links > > > > |
08-21-2006, 13:17
The lower-front load center is behind the grille, and open the panel
with the driver-side wiper on it. The rear load centers were in the frontmost end of the overhead bins (behind wooden boxes), right and left, but moved in '87 to behind the rear overhead door, there is a wood panel held in place by three slide-bolts (queen-island bed model change). - Jeff Miller in Holland, MI > Alan wrote: > > > Ok, I remember now that those side lights are turn lights. > > (Although preliminary tests say they still aren't working.) I'll go > > outside a little later when the temp drops below 105 and try again. > > > > However, I'm still confused on where some of my circuit breakers > > are. My manual shows the following Load Centers: > > > > 1. Lower Front Load Center (This is the one I can't seem to find.) > > 2. Overhead Front Load Center (This appears to be the one in the > > cabinet over the driver.) > > 3. Left Front Load Center (Over couch) > > 4. Right Front Load Center (Over chair) > > 5. Left Rear Load Center (I haven't looked for this one.) > > 6. Right Read Load Center (I haven't looked for this one.) > > > > Where is #1?? > > > > Thanks! > > Alan Johnson > > 87FC35 > > > > > |
08-21-2006, 14:43
True, for 1982-1987. For the other 20 model years of FC however, not.
Be sure that the information you're using to troubleshoot and service your coach is accurate for the year and model you have, some things changed mid-year, several times in several years, etc. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > The FC models have three strips of circuit breakers on the drivers > side front panel. Two across the front and one behind the steering column. |
