Lower Front Load Center on 87FC35
08-23-2006, 15:48
Well, it took me a week, but I finally found this Load Center. I'll
enter this post in case any other unlucky person has the same luck I do. The "Lower Front Load Center" (as it's called in the wiring diagram) is located INSIDE the coach, just to the left of where the drivers left foot would be. It is located behind a panel that is beneath my gear shift buttons (ZF Trans). Maybe my coach is the only one that has it located here. Everyone else's seemed to be behind the grill, underneath the service panel on the driver's side. Mine was not. (No props for the BB service manual on where they hide this stuff.) Anyway, thanks for all your help with this one. I was able to track and fix my side blinkers. (So hopefully I'm set to get some Texas tags.) Alan Johnson 972.333.4755 |
