wheel seal
04-22-2005, 02:58
wheel seal
Good Morning all........Need a little advise please
I will be leaving sunny Florida a week from today so I pulled the bird out of the building and noticed oil on the plywood( I keep the tires off the concreat on plywood)the oil spot was about the size of a small plate....Now you all can probably quess the question.... Can I get back to Wisconsin (1500 miles ) or do I need to address the situation NOW!..........Of course I don;t want to be left on the road so I pretty much figure I need to find someone in the Ocala Fl. area to do the repair....By the way the oil is comming down the curb side inside of the inside dual............Thank again guys.......DAN SAARI 92 WLWB 40 ft. Summerfield Fl./Depere Wi. |
04-22-2005, 03:06
wheel seal
Dan,
Sounds like an axel seal is leaking. The brake shoes are most likely saturated in oil. Do not drive the 1,500 miles without correcting the problem. I just had the same problem but it was the tag axel. Glad the shop noticed it before I took off on a 5,000 mile test drive. Good luck. Curt Sprenger 1987 PT38 Anaheim, Ca. Dan Saari wrote: > > Good Morning all........Need a little advise please > > I will be leaving sunny Florida a week from today so I pulled the bird > out of the building and noticed oil on the plywood( I keep the tires > off the concreat on plywood)the oil spot was about the size of a small > plate....Now you all can probably quess the question.... > > Can I get back to Wisconsin (1500 miles ) or do I need to address the > situation NOW!..........Of course I don;t want to be left on the road > so I pretty much figure I need to find someone in the Ocala Fl. area to > do the repair....By the way the oil is comming down the curb side > inside of the inside dual............Thank again guys.......DAN SAARI > > 92 WLWB 40 ft. > Summerfield Fl./Depere Wi. > |
04-22-2005, 03:07
wheel seal
Yep Dan, its wheel seal time. Since you probably don't
know how fast it leaks, pretty risky to drive 1500 miles. It also has most certainly soaked the brake shoes, so you've lost your brakes on that wheel. Not a real expensive problem, cost about $300 on my '87 PT40 to do the one leaker, including brake shoes. Scott Peatross '87PT40 --- Dan Saari --------------------------------- Good Morning all........Need a little advise please I will be leaving sunny Florida a week from today so I pulled the bird out of the building and noticed oil on the plywood( I keep the tires off the concreat on plywood)the oil spot was about the size of a small plate....Now you all can probably quess the question.... Can I get back to Wisconsin (1500 miles ) or do I need to address the situation NOW!..........Of course I don;t want to be left on the road so I pretty much figure I need to find someone in the Ocala Fl. area to do the repair....By the way the oil is comming down the curb side inside of the inside dual............Thank again guys.......DAN SAARI 92 WLWB 40 ft. Summerfield Fl./Depere Wi. --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. |
04-22-2005, 03:18
wheel seal
Hi Dan
This happened to us last summer. My thought,if it leaks sitting still,it really is going to leak driving down the road. My vote is fix it before you take off. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 |
04-22-2005, 03:52
wheel seal
Dan,
If it does indeed need new shoes, save yourself some headache and replace the brake drum at the same time. The new shoes will seat properly on the new drum. Don't ask how I know! David Brady '02 LXi "Smokey" Virginia Dan Saari wrote: > > Good Morning all........Need a little advise please > > I will be leaving sunny Florida a week from today so I pulled the bird > out of the building and noticed oil on the plywood( I keep the tires > off the concreat on plywood)the oil spot was about the size of a small > plate....Now you all can probably quess the question.... > > Can I get back to Wisconsin (1500 miles ) or do I need to address the > situation NOW!..........Of course I don;t want to be left on the road > so I pretty much figure I need to find someone in the Ocala Fl. area to > do the repair....By the way the oil is comming down the curb side > inside of the inside dual............Thank again guys.......DAN SAARI > > 92 WLWB 40 ft. > Summerfield Fl./Depere Wi. > > > > > ------------------------------------------------------------------------ > *Yahoo! Groups Links* > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > >------------------------------------------------------------------------ > >No virus found in this incoming message. >Checked by AVG Anti-Virus. >Version: 7.0.308 / Virus Database: 266.10.2 - Release Date: 4/21/2005 > > -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.308 / Virus Database: 266.10.2 - Release Date: 4/21/2005 |
