Electric Fuel Pump
04-19-2006, 15:36
Electric Fuel Pump
--- In WanderlodgeForum@yahoogroups.com, "fhulse@..."
wrote: > > somervillebus: > As per Power tech, > Facet fuel pump 4 to 7 lbs. > The one I have is a Purolator # 12S > and inside the package is a 4to7 lb. Facet pump . > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WB41 > Thanks Fred, Purolator is a good brand, I installed a Mr. Gasket that may have been my problem? I replaced it today with another 4-7 lbs Mr. Gasket (warranty covered) fired it up started and ran fine after bleeding injectors. If this one does not last I will change brands. Thanks again |
04-20-2006, 00:28
Electric Fuel Pump
--- In WanderlodgeForum@yahoogroups.com, "somervillebus"
<somervillebus@...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "randydupree2000" > wrote:they do get weak over time,but i've only seen one just quit! randy > > > > --- In WanderlodgeForum@yahoogroups.com, "somervillebus" > > <somervillebus@> wrote: > > >the facet pumps are most times very good,thats what it came with,is > > that what you replaced it with? or you sure its the pump and not the > > oil pressure sending unit? that sendor controls the pump. > > randy dupree > > > Can anyone recommend a good replacement electric fuel pump for a > > > PowerTech generator 15 KW. I've replaced it about 6 months ago and > > > today it give out??? > > > > > > thanks > > > > > > Thanks,Randy I took it off and applied direct 12 volt to it...dead as > a door knob. I installed a new one today, bled the injectors to purge > air runs like a new one. I may have had one of those one out of 500? > > Thanks again. > |
04-20-2006, 00:56
Electric Fuel Pump
Facet is part of Purolator
http://www.facet-purolator.com/ Fuel pumps are handled by the Motor Components Group. Available at NAPA. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "somervillebus" <somervillebus@...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "fhulse@" > wrote: > > > > somervillebus: > > As per Power tech, > > Facet fuel pump 4 to 7 lbs. > > The one I have is a Purolator # 12S > > and inside the package is a 4to7 lb. Facet pump . > > Fred & Jeanne Hulse > > Morristown Arizona > > 1997 Wanderlodge WB41 > > > Thanks Fred, Purolator is a good brand, I installed a Mr. Gasket that > may have been my problem? I replaced it today with another 4-7 lbs Mr. > Gasket (warranty covered) fired it up started and ran fine after > bleeding injectors. If this one does not last I will change brands. > > Thanks again > |
04-20-2006, 02:29
Electric Fuel Pump
Hi all,
I have been reading this tread about the Facet pump... Last year my pump went out on my little westerbeke diesel on the boat and had to get a new Facet pump... The best price that I found was from Spruce aircraft on the web, the local Napa store wanted double what I paid for it on the web... Here is a link to this pump that I bought; http://www.aircraftspruce.com/catalog/ep...erpump.php HTH Sea Ya Larry NYC Wannabe pattypape Facet is part of Purolator http://www.facet-purolator.com/ Fuel pumps are handled by the Motor Components Group. Available at NAPA. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "somervillebus" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "fhulse@" > wrote: > > > > somervillebus: > > As per Power tech, > > Facet fuel pump 4 to 7 lbs. > > The one I have is a Purolator # 12S > > and inside the package is a 4to7 lb. Facet pump . > > Fred & Jeanne Hulse > > Morristown Arizona > > 1997 Wanderlodge WB41 > > > Thanks Fred, Purolator is a good brand, I installed a Mr. Gasket that > may have been my problem? I replaced it today with another 4-7 lbs Mr. > Gasket (warranty covered) fired it up started and ran fine after > bleeding injectors. If this one does not last I will change brands. > > Thanks again > Yahoo! Groups Links --------------------------------- New Yahoo! Messenger with Voice. Call regular phones from your PC and save big. [Non-text portions of this message have been removed] |
