Good stuff for '90's Coaches
12-05-2006, 06:21
Good morning everyone:
Just had some valuable information come my way, due to a break down on the side of the road, that should benefit those that have '90's Coaches. Check transmission light comes on: code 21 To try clearing this alarm, follow this sequence; Trans in neutral press the check transmission button foot on break put transmission in reverse put transmission in neutral put transmission in drive repeat 2 times ending with transmission in neutral tun off transmission check switch This sequence clears the check transmission light and resets the ECU that connects to the DDEC and throttle should be returned to normal at this point. How the system is connected from throttle to DDEC. Throttle position sensor connects to the ECU the ECU then connects to the DDEC. The ECU is the middle man in this case and is effected with low power like the DDEC can be. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma |
