LX DIAGNOSTIC PORT
05-29-2007, 00:04
LX DIAGNOSTIC PORT
Is there a Cummins diesel diagnostic connection in the front of the
1998 LX 40 and if so what data can be read . Is there a Silver Leaf
constant readout unit available and or similar device?
Donald Brown, Palmetto FL looking at a new to me LX
05-29-2007, 00:50
LX DIAGNOSTIC PORT
I have a Silverleaf VMSpc plugged into my DDL. It gives me most information on
the engine, an 8v92. I would think VMSpc is available for the Cummins and the
DDL must be somewhere in the area of the Pilots left knee. That is where mine
is located. Mine is a twelve pin plug. Yours may be 9 pin. You could go on line
at http://www.silverleafelectronics.com and contact them for more specific information.
I imagine you will get more information than I do including transmission info
because your coach is a later model.
I went into my engine data base and there are several Cummins engines listed.
For info, I get most data off of my DDEC II but not oil temperature. Things like
battery voltage, engine load, water temperature, low fluid level, oil pressure,
fuel temperature, rpm, mph, throttle position, boost, gallons per hour, torque,
cruise set speed, HP, engine hours etc. It will also read diagnostic codes if
they occur.
Leroy Eckert
1990WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Tuesday, May 29, 2007 7:04 AM
Subject: [WanderlodgeForum] LX DIAGNOSTIC PORT
