Lights
02-15-2007, 01:20
Lights
It has been cold here. Our bird is under car (rv) port. Have been checking
from time to time. Yesterday found that when connected to power that lights in bath room were very dim. The shower light was bright. The outlet in bath also worked with lamp when it was plugged in. All other outlets worked in coach worked. Would anyone have suggestions as to what is causing problem and fix? Maury 31' 80 fc [Non-text portions of this message have been removed] |
02-15-2007, 02:35
Lights
Hi Maury, If they are fluorscent lights, they may be dim in cold
weather until they have had a chance to warm themselves up - several minutes at least. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "M.L. Perkinson" <mp222116@...> wrote: > > It has been cold here. Our bird is under car (rv) port. Have been checking from time to time. Yesterday found that when connected to power that lights in bath room were very dim. The shower light was bright. The outlet in bath also worked with lamp when it was plugged in. All other outlets worked in coach worked. > > Would anyone have suggestions as to what is causing problem and fix? > Maury 31' 80 fc > > [Non-text portions of this message have been removed] > |
02-15-2007, 03:11
Lights
Rich, Thanks for the quick and accurate response! I went back out and left
lights on long enough to verify your advice. Thanks again. Maury 80 31' fc. ----- Original Message ----- From: g_man1146 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 15, 2007 9:35 AM Subject: [WanderlodgeForum] Re: Lights Hi Maury, If they are fluorscent lights, they may be dim in cold weather until they have had a chance to warm themselves up - several minutes at least. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "M.L. Perkinson" <mp222116@...> wrote: > > It has been cold here. Our bird is under car (rv) port. Have been checking from time to time. Yesterday found that when connected to power that lights in bath room were very dim. The shower light was bright. The outlet in bath also worked with lamp when it was plugged in. All other outlets worked in coach worked. > > Would anyone have suggestions as to what is causing problem and fix? > Maury 31' 80 fc > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.441 / Virus Database: 268.17.39/686 - Release Date: 2/14/2007 7:54 AM [Non-text portions of this message have been removed] |
