What is standard 50amp while traveling
04-30-2005, 10:43
Question for the group....
What is the (normal)standard 50amp camp ground hook ups while traveling? Is the 50amp boxes in most camp grounds 120v @ 50amp or 240v @ 50amp? Does one always want to make sure before hooking up if there seems to be not a general 50amp standard (check for 120v vs. 240v)? Most camp grounds have 120v @ 30amp & 20amp as I recall, but not for sure on the 50amp hook ups that handle the big coaches. I am wanting to do the 50amp box (for my coach)at my house along with the additional 30amp box to cover all needs (in case some one comes to see me), thus the reason for the question. It seems I've alway got by with the 30amp box hook ups and I want to cover all situations of need. Gregg Kizer New Castle,IN 85PT40 |
04-30-2005, 11:28
50a @ 240 is nice when you can find it in a campground. That's what I have in
the 'bird house. Far as I know all 50a is 240 unless the electrician made a major mistake. Mike Hohnstein Germantown WI 83FC35 ----- Original Message ----- From: Gregg Kizer To: WanderlodgeForum@yahoogroups.com Sent: Saturday, April 30, 2005 5:43 PM Subject: [WanderlodgeForum] What is standard 50amp while traveling Question for the group.... What is the (normal)standard 50amp camp ground hook ups while traveling? Is the 50amp boxes in most camp grounds 120v @ 50amp or 240v @ 50amp? Does one always want to make sure before hooking up if there seems to be not a general 50amp standard (check for 120v vs. 240v)? Most camp grounds have 120v @ 30amp & 20amp as I recall, but not for sure on the 50amp hook ups that handle the big coaches. I am wanting to do the 50amp box (for my coach)at my house along with the additional 30amp box to cover all needs (in case some one comes to see me), thus the reason for the question. It seems I've alway got by with the 30amp box hook ups and I want to cover all situations of need. Gregg Kizer New Castle,IN 85PT40 ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
04-30-2005, 12:48
250 (240) volt.
This is the main link you need: http://users3.ev1.net/~crossstitch/RVWiring/wiring.html More misc info: http://www.phrannie.org/surge.html http://www.phrannie.org/battery.html http://www.phrannie.org/phredex.html Dan 94 BMC 37' --- In WanderlodgeForum@yahoogroups.com, "Gregg Kizer" wrote: > Question for the group.... > > What is the (normal)standard 50amp camp ground hook ups while > traveling? Is the 50amp boxes in most camp grounds 120v @ 50amp or > 240v @ 50amp? > > Does one always want to make sure before hooking up if there seems to > be not a general 50amp standard (check for 120v vs. 240v)? Most camp > grounds have 120v @ 30amp & 20amp as I recall, but not for sure on the > 50amp hook ups that handle the big coaches. > > I am wanting to do the 50amp box (for my coach)at my house along with > the additional 30amp box to cover all needs (in case some one comes to > see me), thus the reason for the question. It seems I've alway got by > with the 30amp box hook ups and I want to cover all situations of need. > > Gregg Kizer > New Castle,IN > 85PT40 |
04-30-2005, 15:16
As Mike said: 50a/240v unless improperly wired.
- Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "Gregg Kizer" wrote: > Question for the group.... > > What is the (normal)standard 50amp camp ground hook ups while > traveling? Is the 50amp boxes in most camp grounds 120v @ 50amp or > 240v @ 50amp? > > Does one always want to make sure before hooking up if there seems to > be not a general 50amp standard (check for 120v vs. 240v)? Most camp > grounds have 120v @ 30amp & 20amp as I recall, but not for sure on the > 50amp hook ups that handle the big coaches. > > I am wanting to do the 50amp box (for my coach)at my house along with > the additional 30amp box to cover all needs (in case some one comes to > see me), thus the reason for the question. It seems I've alway got by > with the 30amp box hook ups and I want to cover all situations of need. > > Gregg Kizer > New Castle,IN > 85PT40 |
05-01-2005, 02:16
Hi Gregg (KB9BG @ arrl),
Best way to check/tell is to first plug in your Surge protector. I have to add that close to 1/2 of 50A I've plugged my Surge protector into in last couple of years do not register the 240 that they should. For others not familiar, each leg of a 50 amp connection carries 120 volts when measured/compared to the neutral and/or the ground. The 240 volts referred to, is developed when each of the 120 volt legs is "out of phase" (60 cycle alternating current) with the other leg such that when measured from one hot leg to the other hot leg, 240 volts is the net result. Notice, neither measured to the neutral nor the ground. My experience is that many campgrounds have "jerry-rigged" their older pedestals so each 50 amp leg has its own breaker but many actually carry the same phase and therefore 240V is really not present across the two hot legs. All this is just academic in most cases, as most coaches do not need or use 240V but be careful in either case. John Suter WA5QCT (formerly WA9JPU & WA4JAB) --- Gregg Kizer > Question for the group.... > > What is the (normal)standard 50amp camp ground hook > ups while > traveling? Is the 50amp boxes in most camp grounds > 120v @ 50amp or > 240v @ 50amp? > > Does one always want to make sure before hooking up > if there seems to > be not a general 50amp standard (check for 120v vs. > 240v)? Most camp > grounds have 120v @ 30amp & 20amp as I recall, but > not for sure on the > 50amp hook ups that handle the big coaches. > > I am wanting to do the 50amp box (for my coach)at my > house along with > the additional 30amp box to cover all needs (in case > some one comes to > see me), thus the reason for the question. It seems > I've alway got by > with the 30amp box hook ups and I want to cover all > situations of need. > > Gregg Kizer > New Castle,IN > 85PT40 > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
05-01-2005, 13:16
wrote: > Question for the group.... > > What is the (normal)standard 50amp camp ground hook ups while > traveling? Is the 50amp boxes in most camp grounds 120v @ 50amp or > 240v @ 50amp? Greg, You've gotten good advice in the previous posts.You can also go to: <http://users3.ev1.net/~crossstitch/RVWiring/wiring.html> for info on 30/50 amp wiring. Good technical explanations and pictures/schematics. I used the info when I wired my garage/homebase. I plan on carrying my Klein ac/dc voltage meter with me from now on to check before plugging in and flipping the switch. If yahoo truncates the url I've posted it in the links under RV Wiring. Jim Owens 77 FC33SB (Gas) Sweetie's Dream Lake of the Ozarks, MO |
