Update on the Update on 78 w/ bad 3208
04-29-2007, 15:30
Possibly a good name considering that it might be the third engine in
there! Alright, the engine is in. To me it seems to run out fine, but the mechanic seems to think it still has some noises, possibly a stuck injector. Sounds like every other diesel I've heard, but I'm not the professional. Have to run some cleaner through it and bleed the lines again. If I didn't mention it earlier, they switched mechanics on me for the install. The first one pulled it out, then they brought on a different guy just to put it in. While I had a bit of trepidation at first, he turned out to be a damned fine mechanic. In installing, they had to remove the valve cover because the crankcase breather wouldn't fit. He noted that it hardly appeared used. the oil also was new. There wasn't any dirt or grime on the engine either, and on top of that there were paper stickers from the reman. that couldn't have stayed where they were if this engine had ever been put in a vehicle. Is it possible I snagged up a fresh reman? I can dream can't I? So the seems engine runs fine, although I haven't ran it much. I need to pick up a few things before I'll run it for a long time. The original mechanic was put back on it after it was installed, although there wasn't much left to do other then pump up the fuel, bleed the air, and fire it up. It needs radiator fluid, exhaust gaskets (the donut ones between the header and the rest of the exhaust which are special order), power steering fluid, and that's about it. I might change out some of the fuel line as they seemed to be a little worse for wear, but I'm pretty happy thus far. As for the place of business that installed it, it was more the owner jerking my chain then the mechanics, although I was caught up in an ongoing struggle that seems to be part of the relationship they have. The place is Mission Trails in San Antonio. Don, the owner, put my bus on the back burner until I put the squeeze on him. I'd suggest if anyone goes to this place for work, unless you have a LOT of time to wait, make sure you tell them it needs to be done ASAP. The price remains the same, but you'll be done in a timely manner. I made the mistake of saying no big hurry, and I guess he thought that meant that everyone that came in could go ahead of me. They get a lot of work here, partly because the price is very good ($65 bucks an hour), and partly because of the mechanic that just makes things happen. Carl, the first and permanent mechanic does a decent job if being a little rough around the edges. He's a great guy, will do whatever is required to get your job done, and will talk your ear off if you let him. I spent a lot of time around the shop helping him from time to time. (I was unemployed while the bus was being fixed, I had nothing else to do!) I watched him go beyond what needed to be done, to the point of manufacturing replacement parts he needed. He's an interesting character indeed! So, while I can't say my experience was great, it was satisfactory. Carl has even gone so far as to offer his help on the side to finish putting in the odds and ends that need to be finished...although I can get most of that myself I think. Draining the temporary water out of the radiator and putting in exhaust donuts is easy. Honestly, had I known how simple it was to get the engine out and in I may have done it myself. It took around 25 hours total. To those who have said it was a bear of a job, and that was pretty much everyone I talked to, I don't believe any of them had actually done it. More on all that later! Joshua Long 78FC32 San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Joshua, > I think you should name it 'EngineEater' > > Gardner > 78FC33 (150k on original engine) |
