More lighting 84FC35
05-11-2007, 06:26
--- In WanderlodgeForum@yahoogroups.com, "Jon"
> > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > Not that I don't have enough stuff to keep me busy. But has anyone, > > besides me, noticed that dark area (unlighted)in front of the fridge > on > > the 84FC35SB? And has anyone installed a light there to eliminate > > it? > > > > Stephen, thanks for your help and I'll be in touch. > > > > Keith > > 84FCSB > > > > > > Keith I installed this halogen lights a few years ago and they work > great! Very reasonable to buy and easy to install. The only draw back > in that they are 110 volts and so you either haft to have your > generator on or pluged into shore power. > > http://i2.photobucket.com/albums/y4/1942...C01984.jpg http://i2.photobucket.com/albums/y4/1942...C01985.jpg > > Jon > 78 Wanderlodge > Bremerton Washington > |
05-11-2007, 07:36
Many of the Wanderlodges had the kitchen exhaust fan, that included
the metal tin roof. These can be replaced with a fantastic fan, allowing the day light to shine. This helps during the day light hours & lightens up this area. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Jon" > > --- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > Not that I don't have enough stuff to keep me busy. But has > anyone, > > > besides me, noticed that dark area (unlighted)in front of the > fridge > > on > > > the 84FC35SB? And has anyone installed a light there to > eliminate > > > it? > > > > > > Stephen, thanks for your help and I'll be in touch. > > > > > > Keith > > > 84FCSB > > > > > > > > > > > Keith I installed this halogen lights a few years ago and they work > > great! Very reasonable to buy and easy to install. The only draw > back > > in that they are 110 volts and so you either haft to have your > > generator on or pluged into shore power. > > > > http://i2.photobucket.com/albums/y4/1942...C01984.jpg > http://i2.photobucket.com/albums/y4/1942...C01985.jpg > > > > Jon > > 78 Wanderlodge > > Bremerton Washington > > > |
05-11-2007, 08:39
Good one Stephen. I "think" the light goes out but only extensive
scientific research (open the door, get the beer) will confirm that as a fact. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Stephen Birtles wrote: > I just open the fridge and the light comes on so I can see the beer > Then I close the door and sit and contemplate life or what I have to > do next in the neverending Saga of Keeping up with Bird > Everyone have a great weekend > By the way does anyone know when you close the fridge door does the > light go out > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com > > > > > Keith, > > I went to Houston and picked up several lamps from a forum member > salvaging > > out an 84 for that very reason. My 79 is dark in front of the frig > and the > > sink. I have installed original lamps in both ceiling areas, what a > change. I > > have also noticed looking at other birds that later coaches have > them in front > > of the sink in the ceiling. > > > > Matthew > > 79fc35sb > > So Cal > > > > > > > > ************************************** See what's free at > http://www.aol.com. <http://www.aol.com.> > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] |
05-11-2007, 10:09
why not wire them for 12 volts the bulbs themselve are 12 volt
Also I have some led light bars that would mount in the corner the leds are tipped at 45 degress They may be pretty bright they are aprroximately 20 inches long Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Jon" > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > Not that I don't have enough stuff to keep me busy. But has anyone, > > besides me, noticed that dark area (unlighted)in front of the fridge > on > > the 84FC35SB? And has anyone installed a light there to eliminate > > it? > > > > Stephen, thanks for your help and I'll be in touch. > > > > Keith > > 84FCSB > > > > > > Keith I installed this halogen lights a few years ago and they work > great! Very reasonable to buy and easy to install. The only draw back > in that they are 110 volts and so you either haft to have your > generator on or pluged into shore power. > > http://i2.photobucket.com/albums/y4/1942...C01984.jpg > > Jon > 78 Wanderlodge > Bremerton Washington > |
05-14-2007, 01:24
Keith,
BB parts has the same original style lights you have in the coach. There replacement lights are no longer made by RGM so they are just a tad shorter and will not fit properly in your original light openings. They have the original bezel and the plastic lens & takes the same bulb. Since you are going to install a new one and cut a new hole then it doesn't matter if it is shorter. I have installed one in my ceiling above the dinette across from the sink, works great. I have noticed in pictures of later fc BBs that there is such a light in this area. Matthew 1979 fc35cb So Cal ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-14-2007, 05:08
Thanks for all the replies about the lack of lighting. There is no
fixture in the hallway. One in the bedroom and one in the kitchen. Nothing in between. I saw some LED lights at Costco and almost bought them but I hate using temporary lighting. It almost never works as intended. Soooooo, I guess I'll look for an original style fixture to install with a local switch? Does that light in the fridge work for diet coke also? Keith 84FC35SB --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Keith: > Not at home right now, but is there not a flourescent light in the hallway?? > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > ----- Original Message ---- > From: Keith Strehle > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, May 10, 2007 3:40:46 PM > Subject: [WanderlodgeForum] More lighting 84FC35 > > Not that I don't have enough stuff to keep me busy. But has anyone, > besides me, noticed that dark area (unlighted)in front of the fridge on > the 84FC35SB? And has anyone installed a light there to eliminate > it? > > Stephen, thanks for your help and I'll be in touch. > > Keith > 84FCSB > > > > > > Ask a question on any topic and get answers from real people. Go to Yahoo! Answers and share what you know at http://ca.answers.yahoo.com > > [Non-text portions of this message have been removed] > |
