What is draining my batteries?
05-14-2007, 07:59
I had another thought. If your toilet is air operated as is mine, the slightest
leak would cause the 12v air compressor to cycle unless it is shut off. My shut off switch in on a bracket on top of the air tank that services the toilet. Disregard if your toilet is different. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Ryan Wright To: WanderlodgeForum@yahoogroups.com Sent: Sunday, May 13, 2007 11:40 PM Subject: Re: [WanderlodgeForum] Re: What is draining my batteries? Thanks all for the replies. Lots of excellent suggestions and I'm going through them now. I'd like to "clean this up" for good if at all possible rather than patch it, as I want to be able to boondock without the batteries dying so quickly. So, I can run an extension cord for the chargers for now (good idea there), but I still need to clean up the phantom loads. Replying to some questions & comments: Leroy: > You indicated you set your fridge to run off of AC or gas. If you have an inverter, are > you certain the fridge is not running off the inverter? Yup. Inverter is turned off. Fridge is running on gas - verified. LP gas detector is on, however - gas won't flow with it off. Perhaps that is draining the batteries? I'd be surprised if it pulled that much current, though. Curt: > After installing the EMS system, I'm finding a fantom load of 3 amp as I > watch the EMS system digital read out. How does that monitor the 12 volt side?? I looked at the docs and it looked like just a high voltage unit to me. Or do you have some other monitor for the low voltage? -Ryan [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
05-15-2007, 09:08
Jon, on our early PT's, i believe the block heater is 110 volts.
Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-15-2007, 09:53
Hi Ryan,
Any way you can run a drop cord to your battery charger, and just keep it plugged in? You don't have to run everything off the 50a cord if everything is turned off...all you really need is a 110v extension cord, unplug your battery charger/s from the coach circuit, and plug it into the extension cord. As for the drain, the alarm causes a draw, along with the radio, LED's on your monitor panel, overhead LED segment clocks and timers. If your optima batteries have been discharged a few times, they might be toast...take them to an auto parts store, alternator rebuild shop, or anywhere else where they can load-test the batteries. Your coach came with deep-cycle 6v golf cart batteries (I think) which can sustain a full discharge many times with harming the cells permanently. If your batteries are ruined, I'd recommend re-wiring it back to it's original 6v configuration. If you leave your coach for longer than a few days, and everything is shut off electrically, I'd also consider some kind of battery disconnect switch, that removes the battery 12v circuit completely from the coach (when located at the batteries, you won't even have to kill the master or electronic master switch...just shut off the batteries completely). Good luck... Kevin McKeown Yorba Linda, CA 1986 38' PT ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-15-2007, 12:58
> > Hi folks, > > My new (to me) coach has been parked for the past week in front of my > house while I create it a better parking spot. As a result I can't > reach the 50 amp service on my house so it's disconnected from the > grid. > > My batteries are only lasting ~48 hours before the battery alarm > sounds so I'm having to use the generator to recharge. Every time I > start the genset, "DC charge" meter goes up to 150 amps and takes > hours getting back down. I've run it 6+ hours until "DC charge" was < > 25 amps and the batteries still die a couple of days later. > > So, how do I fix this? "DC Discharge" shows zero (and yes, the meter > works, it goes up when I turn lights on). Nobody has been in the coach > so the lights haven't been used and I turned everything off that I > know of. I set the fridge to run on AC or gas only (no DC, since I > noticed it was hitting the batteries up for juice). The only things I > have on that I know of are: > > 1. Stereo (it's "off", but previous owner wired ACC right to +12v so > it's always lit up - but that should take months to drain four car > batteries, not days). > 2. Battery alarm. > 3. Fridge temp alarm. > > Coach has 6 blue top 12vdc Optima batteries (two engine, four coach) > with 10/05 manufacture dates. Mix of 50 & 55 amp-hour batteries. > > Any advice would be appreciated! > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA Ryan while out in my coach today I thought about your electrical problem and could your engine pre-heater be on? This takes quite alot of juice to opperate-just thought I would through this at you. Jon Bremerton 78 Wanderlodge. > |
05-16-2007, 04:19
On 5/15/07, krminyl@...
> > Any way you can run a drop cord to your battery charger, and just keep it > plugged in? You don't have to run everything off the 50a cord if everything is > turned off...all you really need is a 110v extension cord, unplug your > battery charger/s from the coach circuit, and plug it into the extension cord. Yup. I just did that last night - at least now my batteries should stay charged. Had to run two 12 gauge cords off two different circuits from the garage. I have a pair of "WFCO 75 amp power connectors" for chargers and they draw a solid 13-14 amps each when charging. I suppose I could have only plugged one in, now that I think about it, but I don't know if they are configured to both charge both banks, or one charger per bank, or what, so I plugged 'em both in. > As for the drain, the alarm causes a draw, along with the radio, LED's on > your monitor panel, overhead LED segment clocks and timers. Oh, I figured that, but I can't imagine these things even combined draw enough to drain these batteries. Unless they're of a really poor design, the clocks and LED panels should only draw a small fraction of an amp each. Something else must be draining here - I'm going to track it down as soon as I get the coach up by my house where I can work on it more easily. ![]() > If your optima > batteries have been discharged a few times, they might be toast...take them to > an auto parts store, alternator rebuild shop, or anywhere else where they can > load-test the batteries. Good idea. I think you may be right about the Optimas being toast. Having used Optimas in my DeLorean for a couple of years due to the sealed design (the battery compartment is inside the passenger compartment), I know for a fact they don't handle being discharged. They seem incredibly fragile in that respect. > Your coach came with deep-cycle 6v golf cart > batteries (I think) which can sustain a full discharge many times with harming the > cells permanently. If your batteries are ruined, I'd recommend re-wiring it > back to it's original 6v configuration. If you leave your coach for longer > than a few days, and everything is shut off electrically, I'd also consider > some kind of battery disconnect switch, that removes the battery 12v circuit > completely from the coach (when located at the batteries, you won't even have > to kill the master or electronic master switch...just shut off the batteries > completely). Good call all around. I may take your advice and replace 'em with 6 volt units even if the Optimas aren't toast. I have a brand new high amp battery disconnect switch here, too, which I'll install when I replace the batteries and re-wire. -Ryan |
