toad/trailer wiring diagrams link
05-23-2007, 16:21
Check out these wiring diagrams at the following site
http://www.accessconnect.commmmmmmm/trai...iagram.htm <http://www.accessconnect.commmmmmmm/trai...iagram.htm> Ed Gardels 89sp Arlington Texas [Non-text portions of this message have been removed] |
05-23-2007, 16:28
--- In WanderlodgeForum@yahoogroups.com, "Ed Gardels"
wrote: > Dont know what happened to link. I will try again http://accessconnect.com/trailer_wiring_diagram.htm sorry Ed gardels 89sp > > Check out these wiring diagrams at the following site > > http://www.accessconnect.commmmmmmm/trai...iagram.htm > <http://www.accessconnect.commmmmmmm/trai...iagram.htm> > > Ed Gardels 89sp > > Arlington Texas > > > > [Non-text portions of this message have been removed] > |
05-24-2007, 00:51
As someone else mentioned, there has been an industry standard RV plug
diagram in the Files section of this forum since day 1 at http://autos.groups.yahoo.com/group/Wand...RV%20Plug/ Unfortunately, as has been discussed on the forum in the past, you need to be aware that BB typically did not use the industry standard wiring configuration (not on my 83 or 91), so you will need a meter or test light to identify the wiring on the Bird plug end and re-do it before you can utilize any standard trailer or toad wiring plug. Some people wire their toad/trailer to match the BB plug, but that doesn't make much sense if you ever want to use that trailer with any standard wired vehicle (which all my Jeeps and Suburbans have been from the factory). Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Ed Gardels" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Ed Gardels" > wrote: > > > > Dont know what happened to link. I will try again > http://accessconnect.com/trailer_wiring_diagram.htm > > sorry > Ed gardels 89sp > > > > > Check out these wiring diagrams at the following site > > > > http://www.accessconnect.commmmmmmm/trai...iagram.htm > > <http://www.accessconnect.commmmmmmm/trai...iagram.htm> > > > > Ed Gardels 89sp > > > > Arlington Texas > > > > > > > > [Non-text portions of this message have been removed] > > > |
05-24-2007, 02:17
Thanks Mike,
We need to add a file for the 6-pin plug that many of us use on our toads. I'll see if I can dig something up. David Brady '02 LXi, Smokey NC mbulriss wrote: > > As someone else mentioned, there has been an industry standard RV plug > diagram in the Files section of this forum since day 1 at > http://autos.groups.yahoo.com/group/Wand...RV%20Plug/ > <http://autos.groups.yahoo.com/group/Wand...0Plug\ /> > > Unfortunately, as has been discussed on the forum in the past, you > need to be aware that BB typically did not use the industry standard > wiring configuration (not on my 83 or 91), so you will need a meter or > test light to identify the wiring on the Bird plug end and re-do it > before you can utilize any standard trailer or toad wiring plug. Some > people wire their toad/trailer to match the BB plug, but that doesn't > make much sense if you ever want to use that trailer with any standard > wired vehicle (which all my Jeeps and Suburbans have been from the > factory). > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > --- In WanderlodgeForum@yahoogroups.com > > > wrote: > > > > > > > Dont know what happened to link. I will try again > > http://accessconnect.com/trailer_wiring_diagram.htm > <http://accessconnect.com/trailer_wiring_diagram.htm> > > > > sorry > > Ed gardels 89sp > > > > > > > > Check out these wiring diagrams at the following site > > > > > > http://www.accessconnect.commmmmmmm/trai...iagram.htm > <http://www.accessconnect.commmmmmmm/trai...iagram.htm> > > > <http://www.accessconnect.commmmmmmm/trai...iagram.htm > <http://www.accessconnect.commmmmmmm/trai...iagram.htm>> > > > > > > Ed Gardels 89sp > > > > > > Arlington Texas > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.467 / Virus Database: 269.7.6/815 - Release Date: 5/22/2007 3:49 PM > [Non-text portions of this message have been removed] |
05-24-2007, 04:11
Good point David! Ask and you shall receive (sometimes anyway)!
Please go to the Files section and look in the "RV Plug Wiring Diagrams" file and see if the new 6 pole wiring diagram helps. I converted my trailers to the 7 pin RV style plug in, since my vehicles all have the RV style receptacle. But, like many people I use a 6 pin receptacle on the toad with a converter cable from 7 pin RV plug on the BB side to a 6 pin plug on the toad side. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, David Brady > > Thanks Mike, > > We need to add a file for the 6-pin plug that many of us > use on our toads. I'll see if I can dig something up. > > David Brady > '02 LXi, Smokey > NC > > mbulriss wrote: > > > > As someone else mentioned, there has been an industry standard RV plug > > diagram in the Files section of this forum since day 1 at > > http://autos.groups.yahoo.com/group/Wand...RV%20Plug/ > > <http://autos.groups.yahoo.com/group/Wand...0Plug\ /> > > > > Unfortunately, as has been discussed on the forum in the past, you > > need to be aware that BB typically did not use the industry standard > > wiring configuration (not on my 83 or 91), so you will need a meter or > > test light to identify the wiring on the Bird plug end and re-do it > > before you can utilize any standard trailer or toad wiring plug. Some > > people wire their toad/trailer to match the BB plug, but that doesn't > > make much sense if you ever want to use that trailer with any standard > > wired vehicle (which all my Jeeps and Suburbans have been from the > > factory). > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com > > > > wrote: > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > wrote: > > > > > > > > > > Dont know what happened to link. I will try again > > > http://accessconnect.com/trailer_wiring_diagram.htm > > <http://accessconnect.com/trailer_wiring_diagram.htm> > > > > > > sorry > > > Ed gardels 89sp > > > > > > > > > > > Check out these wiring diagrams at the following site > > > > > > > > http://www.accessconnect.commmmmmmm/trai...iagram.htm > > <http://www.accessconnect.commmmmmmm/trai...iagram.htm> > > > > <http://www.accessconnect.commmmmmmm/trai...iagram.htm > > <http://www.accessconnect.commmmmmmm/trai...iagram.htm>> > > > > > > > > Ed Gardels 89sp > > > > > > > > Arlington Texas > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.467 / Virus Database: 269.7.6/815 - Release Date: 5/22/2007 3:49 PM > > > > > > [Non-text portions of this message have been removed] > |
05-24-2007, 14:46
Thanks Mike!
David B. '02 LXi, Smokey NC mbulriss wrote: > > Good point David! Ask and you shall receive (sometimes anyway)! > Please go to the Files section and look in the "RV Plug Wiring > Diagrams" file and see if the new 6 pole wiring diagram helps. I > converted my trailers to the 7 pin RV style plug in, since my vehicles > all have the RV style receptacle. But, like many people I use a 6 pin > receptacle on the toad with a converter cable from 7 pin RV plug on > the BB side to a 6 pin plug on the toad side. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > Thanks Mike, > > > > We need to add a file for the 6-pin plug that many of us > > use on our toads. I'll see if I can dig something up. > > > > David Brady > > '02 LXi, Smokey > > NC > > > > mbulriss wrote: > > > > > > As someone else mentioned, there has been an industry standard RV plug > > > diagram in the Files section of this forum since day 1 at > > > > http://autos.groups.yahoo.com/group/Wand...RV%20Plug/ > <http://autos.groups.yahoo.com/group/Wand...0Plug\ /> > > > > > <http://autos.groups.yahoo.com/group/Wand...0Plug\ / > <http://autos.groups.yahoo.com/group/Wand...0Plug\ />> > > > > > > Unfortunately, as has been discussed on the forum in the past, you > > > need to be aware that BB typically did not use the industry standard > > > wiring configuration (not on my 83 or 91), so you will need a meter or > > > test light to identify the wiring on the Bird plug end and re-do it > > > before you can utilize any standard trailer or toad wiring plug. Some > > > people wire their toad/trailer to match the BB plug, but that doesn't > > > make much sense if you ever want to use that trailer with any standard > > > wired vehicle (which all my Jeeps and Suburbans have been from the > > > factory). > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > wrote: > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > wrote: > > > > > > > > > > > > > Dont know what happened to link. I will try again > > > > http://accessconnect.com/trailer_wiring_diagram.htm > <http://accessconnect.com/trailer_wiring_diagram.htm> > > > <http://accessconnect.com/trailer_wiring_diagram.htm > <http://accessconnect.com/trailer_wiring_diagram.htm>> > > > > > > > > sorry > > > > Ed gardels 89sp > > > > > > > > > > > > > > Check out these wiring diagrams at the following site > > > > > > > > > > http://www.accessconnect.commmmmmmm/trai...iagram.htm > <http://www.accessconnect.commmmmmmm/trai...iagram.htm> > > > <http://www.accessconnect.commmmmmmm/trai...iagram.htm > <http://www.accessconnect.commmmmmmm/trai...iagram.htm>> > > > > > > <http://www.accessconnect.commmmmmmm/trai...iagram.htm > <http://www.accessconnect.commmmmmmm/trai...iagram.htm> > > > <http://www.accessconnect.commmmmmmm/trai...iagram.htm > <http://www.accessconnect.commmmmmmm/trai...iagram.htm>>> > > > > > > > > > > Ed Gardels 89sp > > > > > > > > > > Arlington Texas > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > No virus found in this incoming message. > > > Checked by AVG Free Edition. > > > Version: 7.5.467 / Virus Database: 269.7.6/815 - Release Date: > 5/22/2007 3:49 PM > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.467 / Virus Database: 269.7.7/816 - Release Date: 5/23/2007 3:59 PM > [Non-text portions of this message have been removed] |
