Stair Cover
08-01-2007, 16:49
Stair Cover
A previous owner removed the hinged stair cover that usually mounts to
the half closet on my 1977 FC31. It has carpet on one side, and the same woodgrain formica on the other that is through out my bus. This nifty item folds down over the stairs, making that area level with the rest of the bus. I would like to reinstall this for the benefit of my older sister, who has hip problems. There are four screw holes thru which large screws were used to mount it thru the carpet, and to the floor. Does any FC owner have one of these, and if so would you pls. measure the length of the (4) scews, and let me know. I want to make sure that I install screws long enough to hold the cover intact, but don't want to send then so deep as to reach China, or some electrical wire that BB hid under there some yrs. ago. TIA George Burke 1977FC31 Charlotte |
08-02-2007, 04:55
Stair Cover
George,
I don't know if mine is the same as yours but the cover has #14 x 3/4" screws in it. The screws that attach to the coach are #14 x 1 1/2", but they are attached into coach parallel to the floor. Hope that helps you out. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of George Burke Sent: Wednesday, August 01, 2007 11:49 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Stair Cover A previous owner removed the hinged stair cover that usually mounts to the half closet on my 1977 FC31. It has carpet on one side, and the same woodgrain formica on the other that is through out my bus. This nifty item folds down over the stairs, making that area level with the rest of the bus. I would like to reinstall this for the benefit of my older sister, who has hip problems. There are four screw holes thru which large screws were used to mount it thru the carpet, and to the floor. Does any FC owner have one of these, and if so would you pls. measure the length of the (4) scews, and let me know. I want to make sure that I install screws long enough to hold the cover intact, but don't want to send then so deep as to reach China, or some electrical wire that BB hid under there some yrs. ago. TIA George Burke 1977FC31 Charlotte [Non-text portions of this message have been removed] |
08-02-2007, 07:31
Stair Cover
I have an 1980 , and the screws on mine are 1 5/8 long .Maybe a 1/4 " thick.
Fred Wells George Burke hinged stair cover that usually mounts to the half closet on my 1977 FC31. It has carpet on one side, and the same woodgrain formica on the other that is through out my bus. This nifty item folds down over the stairs, making that area level with the rest of the bus. I would like to reinstall this for the benefit of my older sister, who has hip problems. There are four screw holes thru which large screws were used to mount it thru the carpet, and to the floor. Does any FC owner have one of these, and if so would you pls. measure the length of the (4) scews, and let me know. I want to make sure that I install screws long enough to hold the cover intact, but don't want to send then so deep as to reach China, or some electrical wire that BB hid under there some yrs. ago. TIA George Burke 1977FC31 Charlotte --------------------------------- Got a little couch potato? Check out fun summer activities for kids. [Non-text portions of this message have been removed] |
08-02-2007, 10:41
Stair Cover
George,
08-04-2007, 10:24
Stair Cover
My thanks to Fred and Chet for their help. The # 14, 1 and 1/2 in. SS
screws worked perfectly. The staircase cover looks great, and works like it was designed to. I do not understand why a previous owner took it off. Now theres one less thing in the Job Jar. Thanks Guys, George Burke 1977FC31 Charlotte--- In WanderlodgeForum@yahoogroups.com, "George Burke" > > A previous owner removed the hinged stair cover that usually mounts to > the half closet on my 1977 FC31. It has carpet on one side, and the > same woodgrain formica on the other that is through out my bus. This > nifty item folds down over the stairs, making that area level with the > rest of the bus. I would like to reinstall this for the benefit of my > older sister, who has hip problems. There are four screw holes thru > which large screws were used to mount it thru the carpet, and to the > floor. Does any FC owner have one of these, and if so would you pls. > measure the length of the (4) scews, and let me know. I want to make > sure that I install screws long enough to hold the cover intact, but > don't want to send then so deep as to reach China, or some electrical > wire that BB hid under there some yrs. ago. TIA George Burke 1977FC31 > Charlotte > |
