					water leak suggestions
					10-12-2007, 07:48
				 Post: #1 | |||
					So I continued my investigation of the water leaking out of the hole above the engine to the drivers side of the coolant resevoir. I looked all around the water heater inside and it is very dry, I looked under the bed and everything is dry there. I also checked and the water is hot out of the faucets. Basically everything seems to be working correctly. So should I replace thermostadts on the water heater? Or is this some normal drainage? I turned the water heater off to see if that makes the dripping stop. It has been dripping for several days now and the water heater has been on for the last year or so while it has been parked. I probably should have it off, but every once in a while we go out and sleep in it just for fun and it is nice to be able to have hot water ready. Thanks for all your advice it is really a big help to me. Robert Rahn Kalispell, Mt. 1988 PT 40 | |||
					10-12-2007, 08:45
				 Post: #2 | |||
					I skipped over the earlier part of this thread as I don't have a hot water heater (but have the continuous hot water from the AquaHot). Did you check the pressure relief valve on the hot water heater? That is the usual culprit. The relief valve allows hot water to escape if the pressure becomes too high. Usually, only a small amount comes out from time to time. Over time, the springs in the valve tend to weaken -- then the valve may allow a drip or leak to continue. The operation of the hot water heater isn't compromised (you still have hot water) but you'll have a small drip-drip-drip or even a trickle of hot water coming out. Since you've left the water heater operating for long periods without using the water, this would tend to cause repeated release of the release valve, contributing to its early failure. The relief valves are a common item and you can get a replacement from a home center for a few dollars. I've had this happen with my home hot water heater.... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Idaho Springs, CO On Oct 12, 2007, at 1:48 PM, Robert & Teri Rahn wrote: > So I continued my investigation of the water leaking out of the hole > above the engine to the drivers side of the coolant resevoir. I looked > all around the water heater inside and it is very dry, I looked under > the bed and everything is dry there. I also checked and the water is > hot out of the faucets. Basically everything seems to be working > correctly. So should I replace thermostadts on the water heater? Or is > this some normal drainage? I turned the water heater off to see if > that > makes the dripping stop. It has been dripping for several days now and > the water heater has been on for the last year or so while it has been > parked. I probably should have it off, but every once in a while we go > out and sleep in it just for fun and it is nice to be able to have hot > water ready. > Thanks for all your advice it is really a big help to me. > > Robert Rahn > Kalispell, Mt. > 1988 PT 40 > > > | |||
					10-13-2007, 08:52
				 Post: #3 | |||
					Another possible culprit is the air actuated water heater drain. I suspect Pete is probably correct though. Is the water that is coming out hot? Regards, Jim | |||
					10-14-2007, 15:05
				 Post: #4 | |||
					--- In WanderlodgeForum@yahoogroups.com, "scoggins_jim" <scoggins.j@...> wrote: >The water coming out is just a very slow drip and the temp here is in the 30 s so it is cold. > Another possible culprit is the air actuated water heater drain. I > suspect Pete is probably correct though. Is the water that is coming > out hot? > > Regards, > Jim > | |||
					10-14-2007, 15:05
				 Post: #5 | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
